IOMEM set to: 25 and the Router keeps rebooting
Hi guys,
Because of a NATTING error, I had to change a memory parameter. Following a thread I found, I set the memory-size as follows:
memory-size iomem 25
After that, the router worked fine for a couple of days but after the restart it started returning memory errors. Even booting in ROMMOD, I get the following error message,
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x20beff4
Self decompressing the image : ############################################################################################################################################################################## [OK]
IOMEM set to: 25
25 percent IO memory configuration is too large. Decreasing to 29360128 bytes.
PMem allocated: 104857600 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 15:45 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
%Software-forced reload
07:59:44 UTC Tue Aug 7 2012: Breakpoint exception, CPU signal 23, PC = 0x6066F228
   Possible software fault. Upon reccurence,  please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x6066B368z 0x60669834z 0x602B3468z 0x602D0524z 0x602CED84z 0x602CEF10z 0x61E3464Cz 0x61E34630z
$0 : 00000000, AT : 63EE0000, v0 : 00000018, v1 : 00000000
a0 : 00000000, a1 : 62C3E41C, a2 : 00000000, a3 : 62C40000
t0 : 640006C8, t1 : 641C0000, t2 : 60674A68, t3 : FFFF00FF
t4 : 00000001, t5 : 63AEFC0C, t6 : 63AF0000, t7 : A00059D0
s0 : 00000000, s1 : 00000000, s2 : 63AF0000, s3 : 63BE0000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 62AEA46C
t8 : 00008000, t9 : 641C0000, k0 : 3041E801, k1 : 00100000
gp : 63EE1D40, sp : 64F77C70, s8 : 64F6BA7C, ra : 6066D6F4
EPC  : 6066F228, ErrorEPC : BFC05FDC, SREG     : 3401FF03
MDLO : 0001E848, MDHI     : 00000000, BadVaddr : 77EF7FE5
TEXT_START : 0x600137C0
DATA_START : 0x62883EC0
Cause 00000024 (Code 0x9): Breakpoint exception
File flash:crashinfo_20120807-075944 Device Error :No such device
File lic0:crashinfo_20120807-075944 Device Error :No such device
File lic1:crashinfo_20120807-075944 Device Error :No such device
Any idea? I am not interested in keeping the old configuration. I am more than happy to reset it completely if you tell me how to do it.
Dario
rmcarthur
Hi Dario, your system doesn't meet the minimum requirements for the image you are trying to load.
12.4(24)T Adv Security requires 192MB dram/64MB flash
You have only 128MB dram
The latest 12.4 image Adv Security image I could see that will run with 128MB dram is 12.4(25)f.
Please downgrade to this version or earlier and report if error clears.
6 Replies 6
johnlloyd_13
Level 9
Level 9
Hi Dario,
I've replied to your other post. As per the 1841's output, kindly raise this issue with Cisco TAC:
Possible software fault. Upon reccurence, please collect crashinfo, "show tech" and contact Cisco Technical Support.
rmcarthur
Hi guys.
I have inherited this router already equipped with that OS. I guess tomorrow I will organize to add an extra module of ram.
Just a question that may be silly for you guys: can I recycle an SDRAM module from an old computer or do I have to use a particular module for Cisco?
Dario
Hi Dario, it's been a while since I've had the lid of one of these but I'm pretty sure it's a single expansion slot SODIMM (more like laptop dram than PC dram) with 128MB soldered on board.
If you can, I'd recommend downgrading the IOS first just to verify that there isn't an underlying issue with your hardware. If that works, you can then upgrade with a suitable SODIMM and reload your current software.
Ross
Thanks guys,
I've ordered 256MB of extra ram. The price is low so I prefer to keep the existing OS. I wish it will work.
Dario
Good luck with the upgrade Dario, let us know how it goes.
Please remember to rate useful posts.
Ross
