IOS Features Understanding
cindylee27
Hi Experts,
I am trying to understand currently on this IOS..My customer has c3660-jk9s-mz.122-29.bin but I would like to make sure that this is IPSEC Supported.. with crypto commands that I can configure.
From the Cisco Navigator Tool, I got this 3 features..
IPSec Network Security
IPSec Triple DES Encryption (3DES)
IPSec Policy Agent II
Do this router has crypto command as I need to let customer knows about this before going for that router.
On the other hand, I have another IOS with ONLY IPSec Policy Agent II , Does this only feature support crypto command?
The IOS is c3660-js-mz.122-28a.bin.
Thanks.
2 Accepted Solutions
Edison Ortiz
Yes, c3660-jk9s-mz.122-29.bin supports crypto commands.
No, c3660-js-mz.122-28a.bin does not support any crypto command.
Danilo Dy
Maybe this link can provide the feature of IOS packaging for 3660 http://www.cisco.com/en/US/products/hw/routers/ps274/prod_bulletin09186a0080161089.html which tells
c3660-jk9s-mz.122-29.bin is ENTERPRISE PLUS IPSEC 3DES (definitely with Crypto)
c3660-js-mz.122-28a.bin is ENTERPRISE PLUS (definitely no Crypto)
Dandy
5 Replies 5
bvsnarayana03
Level 5
Level 5
You can check all features on the lnik below:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
pls rate all helpful posts.
Hi Narayana,
Actually tat was the link I checked and got those features but I need to know if IPSEC Policy Agents II will have crypto map commands supported in that particular router..
Thanks.
Edison Ortiz
Danilo Dy
Dandy
Thanks Guys ! and post rated..:)
