07-04-2007 12:39 AM - edited 03-03-2019 05:43 PM
i have an ios file "c2800nm-ipbase-mz.124-3g" for c2851 router.its not supporting bgp .i need an ios file name and ios for c2851 which supports bgp,version 12.4()3g).this is an urgent requirement
07-04-2007 12:54 AM
The easiest way to do this is to use Cisco's Feature Navigator Tool. Had a look for you
Advanced IP services supports BGP
c2800nm-advipservicesk9-mz.12.4-3g.bin
as does
Enterprise Services
c2800nm-entservicesk9-mz.12.4-3g.bin image
Jon
07-04-2007 01:00 AM
hi,
thanks,do u have any ways to download the ios file
c2800nm-advipservicesk9-mz.12.4-3g.bin .i don't have cisco cco login.
07-04-2007 01:16 AM
Unfortunately it's not as simple as that. Because you are upgrading to an image with more features in it there may well be a cost involved.
You need to talk to whoever you normally deal with when purchasing Cisco kit.
Jon
07-04-2007 01:42 AM
fine,how to install the ios in an router,basic steps reqd
07-04-2007 01:51 AM
HI Prasanna,
CISCO IOS installation & upgradation procedure:
http://www.cisco.com/warp/public/130/sw_upgrade_proc_ram.shtml#topic1
Pls Rate if HELPS
Best Regards,
Guru Prasad R
07-04-2007 02:14 AM
hi guruprasad,
thanks.in the procedure,it says
Download a TFTP server. Refer to TFTP Server Selection and Use for more information.
Configure the TFTP application to operate as a TFTP server instead of a TFTP client.
u can specify the tftp server reqd and the link to download itand the steps reqd to operate as an server.
07-04-2007 02:27 AM
HI Prasanna,
"SolarWinds" - is a very good tool for TFTP Server.
You can download a Trial Version / even from http://www.download.com/3120-20_4-0.html?tg=dl-20&qt=SolarWinds&tag=srch
For step-by-step procedure to Setup an TFTP Server (as SolarWinds) - Pls refer Link below:
Pls do RATE / VOTE all Helpful Replies
Best Regards,
Guru Prasad R
07-04-2007 05:34 AM
hi guruprasad
sure,i will check the links given by you.i am leaving out
thanks a lot
keep in touch
prasanna
07-05-2007 05:30 AM
For TFTPD server if you are running a Windows platform I would suggest;
TFTPD32, which is a free download from;
It also includes a DHCP and syslog server functionality. Recommended by Cisco as well.
