OSPF Peer Limitation
hsharman
I need that information if it is available:
How many OSPF peer does Cisco router support? For example; Cisco 7206VXR
router supports how many OSPF peer on its one of the ethernet or serial
interface?
Tansel Akyuz
Network Engineer
TUVTURK
mounir.mohamed
Level 7
Level 7
It's depending on allot of verities for example the OSPF router may have multiple point-to-point interfaces into different areas or the same area (As per Cisco recommendation the router should not belong to more than 3 different areas) I the same time the router may be elected as the DR on the Ethernet segment so finally it?s deepening on the router resources.
Best Regards,
Mounir Mohamed
Welcome Mounir... good to see you back in the forum
Yes i agree with Mounir that it totally depeneds on the router resources.
These are however some Cisco OSPF design recommendations
routers per area - 50
neighbors per router - 3
areas per router - 3
Bit again this may differ according to your network topology and traffic patterns
Narayan
inzeos781
You could also consider forcing your down stream routers to only create two adjacencies with the DR and BDR to speed up convergence.
