IOS issue with the Cisco 7206
vinoth.kumar
We are using the router 7206 VXR NPGE2 with the version
bootstrap version 12.4 (12.2r)T,release software FC1
System image file "bootflash:c7200p-k91p-mz.122-31.SB10.bin
which is doesnt support NAT so we need the latest support version for the router
can any one advice
Vinu
10 Replies 10
Edison Ortiz
Try c7200p-spservicesk9-mz.124-15.T8.bin
__
Edison.
i tried upload the image in disk2 and in the Rmon i given
Rmon> boot disk2: c7200p-spservicesk9-mz.124-15.T8.bin
after reset i say the error
The message from the bootldr
String is disk2:c7200p-spservicesk9-mz.124-15.T8.bin
loadprog: errorr -invalid image for this platform
CPU type = 169
boot = cannot find an excutable image for ths platform on device slot 1
Vinu
That's odd. That image is supposed to work on NPE-G2.
Please boot with the other image and paste the output from show diag and show ver
__
Edison.
please find the output of the two commands
Router#sh version
Cisco IOS Software, 7200 Software (C7200P-K91P-M), Version 12.2(31)SB10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 16-Nov-07 04:08 by richv
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "bootflash:c7200p-k91p-mz.122-31.SB10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 21268035
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.0
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 FastEthernet interfaces
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2142
Router#sh diag
Slot 3:
Dual Port FastEthernet (RJ45) Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:01:20 ago
EEPROM contents at hardware discovery:
Controller Type : 548
Hardware Revision : 1.1
PCB Serial Number : JAE063007QA
PCB Part Number : 73-5419-07
Board Revision : A0
RMA Test History : 07
RMA Number : 0-0-0-0
RMA History : 00
Deviation Number : 0-0
Product Identifier (PID) : PA-2FE-TX
Top Assy. Part Number : 800-08350-06
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 02 24 41 01 01 C1 8B 4A 41 45 30 36 33
0x10: 30 30 37 51 41 82 49 15 2B 07 42 41 30 03 07 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 50 41 2D
0x30: 32 46 45 2D 54 58 20 20 20 20 20 20 20 20 20 20
0x40: 20 C0 46 03 20 00 20 9E 06 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Router#
Did you format the compact flash holding the IOS image?
If not, format the compact flash - copy the image once again onto the flash and try again.
__
Edison.
You cannot have a space between disk2 and the IOS file name, this causes the router to be unable to find the IOS.
"Rmon> boot disk2: c7200p-spservicesk9-mz.124-15.T8.bin"
When i am trying to copy the image itself it says the message that the image is not excuatble for the platform
Router#copy tftp: disk2:
Address or name of remote host [192.168.1.10]? 192.168.1.10 Source filename [c7200-spservicesk9-mz.124-15.T8.bin]? c7200-spservicesk9-mz.124-15.T8.bin
Destination filename [c7200-spservicesk9-mz.124-15.T8.bin]?
Accessing tftp://192.168.1.10/c7200-spservicesk9-mz.124-15.T8.bin...
%Warning: File not a valid executable for this system
Abort Copy? [confirm]n
Loading c7200-spservicesk9-mz.124-15.T8.bin from 192.168.1.10 (via GigabitEthernet0/1):
Intern of boot from the image it says the error
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
loadprog: error - Invalid image for platform
e_machine = 25, cpu_type = 169
boot: cannot load "cisco2-C7200"
Please suggest
Vinu
Vinu,
You downloaded the image for the NPE-G1, not the image for the NPE-G2. Notice the 'p' missing on the c7200 as part of the filename.
Download the correct image and try again.
__
Edison.
Thanks it working now
Is there specific command or any way i can monitor what are configuration changes we are doing
Since suddenly some chnage are happening on our router configuration
