Bookmark
Subscribe
1638
IOS known issues
Peter Kiogora
does this ios have any known issues : Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Edison Ortiz
That's a broad question as issues are often related to the services you are using.
You can start with the Caveats section within the Release Notes:
http://www.cisco.com/en/US/docs/ios/15_0/release/notes/150MCAVS.html
On that URL, you will find a link to the bug toolkit. You can run a search of bugs that matches your release and determine if the bug will impact your network.
Edison
Edison Ortiz
Edison
