IOS not supporting ATM module and IOS question
bissrached
Hello
I have installed an ATM module (NM-1A-OC3SMI) in a 3745 router with IP Base image. Since the module was not supported, i upgraded to IP Plus image "c3745-is-mz.123-16.bin" as per software advisor. Still the module is under unknown for the router. Anyone can help?
Another question is that the show version shows that ROM has the IPBASE image and the system boot image is the flash one, the IP Plus image; does this relates somehow. The configuration register value should boot from flash
#sh ver
IOS (tm) 3700 Software (C3745-IS-M), Version 12.3(16), RELEASE SOFTWARE
(fc4)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 23-Aug-05 16:46 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61C40000
ROM: System Bootstrap, Version 12.3(6r) [cmong 6r], RELEASE SOFTWARE (fc1)
ROM: 3700 Software (C3745-IPBASE-M), Version 12.3(9e), RELEASE SOFTWARE
(fc1)
Router uptime is 6 minutes
System returned to ROM by reload
System image file is "flash:c3745-is-mz.123-16.bin"
cisco 3745 (R7000) processor (revision 2.0) with 250880K/11264K bytes of
memory.
Processor board ID FCZ094571XZ
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 FastEthernet/IEEE 802.3 interface(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31744K bytes of ATA System CompactFlash (Read/Write)
thank you
ajagadee
Bassam,
The reason that card is not getting recognized because it is not supported on the 3745.
NM-1A-OC3SMI is supported on the 3725 and not on the 3745. For the 3745, you need to Enhanced Performance Version which is NM-1A-OC3SMI-EP.
REFERENCES
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_module_installation_guide_chapter09186a008007c8f4.html#wp1041386
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_module_installation_guide_chapter09186a008007c8c4.html#wp1120288
Let me know if it helps.
Arul
ajagadee
Bassam,
REFERENCES
Arul
Sure this helped
Thank you Arul
bassam
