IOS types
ncnaveen_arasu
What are the difrent types of IOS available for cisco routers and switches, like IOS-XR etc. for what platform we will use the diffrent IOS.
Thanks in advance.
Naveen
joelgooding
For each device, router or switch, the data sheet for the item has a description of what compatible ios's are compatible. If you cannot find it there do an ios lookup on the support section to check. If you still cannot find it there, raise a tac case or speak to an agent on the main page chat
Sent from Cisco Technical Support Android App
Joel _______________________________ Please rate helpful posts and answered questions!
