IOS updgrage in Cisco 3850
jahanzeb.feroze
Dear All
I have updated IOS on cisco core 3850, it has come to flash but still it is not shown in "sh version" command and also i am unable to boot from this new IOS, kindly mention the steps how to boot from the new IOS.
Thanks and Regards
Jahanzeb
2 Accepted Solutions
Tiago Marques
what is the ios you have uploaded?
switch is on-line??or not??
i have upgraded very 3850 with this (http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html) and result ok!
see the link
3850 normaly use command:
software install file flash:cat3k_caa-universalk9.SPA.03.06.01.SE.150-1.EZ1.bin
7 Replies 7
Mark Malone
Hey can you post the output from dir and also your show boot
as well which image are you going too?
I want to boot from below mention IOS,
cat3k_caa-universalk9.SPA.03.06.01.SE.150-1.EZ1.bin,
It is successfully uploaded in flash, but my switch still booting from old IOS, i-e mention below
cat3k_caa-universalk9.SPA.03.02.01.SE.150-1.EZ1.bin, what to do to boot it from new IOS?
I would suggest you to change the boot priority of the switch if it is having two IOS.
switch(config-t)#boot-start-marker
switch(config-t)#boot system flash: new IOS
switch(config-t)#boot system flash: old IOS
switch(config-t)#boot-end-marker
switch(config-t)#do write
Reboot the switch afterward and it should start with the new IOS.
With Regards
Chinmoy
Tiago Marques
see the link
i have loaded below mention IOS,
LJ Gabrillo
Level 5
Level 5
Hi Jahan,
That is now how you upgrade the 3850 model.
The 3650 and 3850 has a different way to upgrade the switch
Before proceeding, verify what boot type your switch uses. Most of what I encounter are "Install mode"
Anyway, follow steps below:
1. Verify Install type
#dir flash:
#show version
**IF:
A. INSTALL MODE
1. *.pkg files are present
2. DO: #show version
LOOK FOR: System bundle file is:
DISPLAYS: "flash:packages.conf"
B. BUNDLE MODE
1. *.bin file only
DISPLAYS: <Another file compared to the file mentioned above>
Once you have verified the install type, proceed with the proper firmware update.
SEE THIS LINK: CLICK ME
Again, please consider what your switch is currently set to: Either Install mode and Bundle mode
All the instructions should be on the link i provided :)
