IOS Upgradation failed Cisco 800 Series Router
gopishukla
Hi All,
I am facing an error while upgrading IOS for Cisco 800 series routers , please check the below error and advice me
Error: Failed to compute md5 hash for flash:/ir800-universalk9-mz.SPA.159-3.M5
IOS md5 verification failed!
Failed to remove corrupted IOS image: flash:/ir800-universalk9-mz.SPA.159-3.M5
Thanks in Advance
14 Replies 14
balaji.bandi
i want to check 2 things here :
1. the file name end with .bin file, this was missing in your syntax
2. try dirt flash: ( take the full name and do same check again)
3. if that fails ( may be you copied wrong file, so download again from cisco download, copy again and test it.
BB
Thanks for your email , i used the below command
bundle install flash: ir800-universakk9-bundle.SPA.159-4.M5.bin
and receiving the below error after end of the process
Hope it will help you for giving solutions .
Ok suggest to post below output :
show version
dir flash:
BB
Hello Mr. Balaji
Below are the response for your reference , looking forward a further support from your side ,
dir flash:
Directory of flash:/
1 -rw- 223099651 Jun 28 2022 04:17:36 -04:00 ir800-universalk9-bundle.SPA.159-3.M5.bin
2 -rw- 0 May 22 2022 21:27:34 -04:00 fs_recovered
3 drw- 0 Sep 14 2017 03:36:26 -04:00 managed
13 drw- 0 Sep 14 2017 03:36:26 -04:00 eem
14 -rw- 75282225 Jul 20 2020 11:09:40 -04:00 ir800-universalk9-mz.SPA.159-3.M1
15 drw- 0 Sep 28 2020 18:40:56 -04:00 .fwupgrade
16 drw- 0 Jun 29 2022 00:56:14 -04:00 ORPHAN1
19 -rw- 119046 Jul 20 2020 14:01:24 -04:00 crashinfo_20200720-175839-UTC
994951168 bytes total (620724224 bytes free)
sh version
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.9(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 30-Jan-20 11:26 by prod_rel_team
ROM: Bootstrap program is IR800
ESNG_RTR21 uptime is 5 weeks, 2 days, 2 hours, 59 minutes
System returned to ROM by Power-on at 09:15:19 PDT Mon Aug 10 2020
System image file is "flash:/ir800-universalk9-mz.SPA.159-3.M1"
Last reload reason: Power-on
Thanks in Advance
Hello
I used the complete file name as upgraded more than 30 routers using the same IOS file , but few devices having the same issues ,
please share the check flash complete command as you mentioned in your response to try ,
Thanks in advance
I don't see how this was possible.
The filename of the error message says "ir800-universalk9-mz.SPA.159-3.M5" but we all know this is not correct, because:
1.  The filename does not have an extension
2.  The filename is incomplete.  The correct filename has a "bundle" in the middle.
So not sure how the 30 routers were upgraded with the wrong filename.
Hello Leo
Thanks for your message, below is the complete command and output, it might help to correct me
bundle install flash:ir800-universalk9-bundle.SPA.159-3.M5.bin
Installing bundle image: /ir800-universalk9-bundle.SPA.159-3.M5.bin.........................................................................................................................................................................................................
updating Hypervisor image...
Starting File System integrity check
NOTE: File System will be deinited and later rebuilt
Starting partition 0 Analysis
Boot Sector/Boot Parameter Block check ...[Passed]
DIB not present
DIB & Monlib check ...[Passed]
Partition Init check ...[Passed]
Directory entries check ...[Passed]
SRP md5 verification passed!
updating IOS image...
DIB not present
Creating orphan file: 20935 4603
Creating orphan file: 25538 1
Creating orphan files under /ORPHAN1
Directory entries check ...[Passed] Error: failed to compute md5 hash for flash:/ir800-universalk9-mz.SPA.159-3.M5
Failed to remove corrupted IOS image: flash:/ir800-universalk9-mz.SPA.159-3.M5!
Oh, wait.  I know what this is.
Clean up the ORPHAN sub-directory.  There is a file in there called "ir800-universalk9-mz.SPA.159-3.M5" which the script cannot remove.
Hello  Leo
Thanks for your quick response, can you pass the command line to clean the file,
Hello Leo ,
There is no such file name as you mentioned, below is the screenshot for your reference and further support.
delete flash:ir800-universalk9-bundle.SPA.159-3.M5
Delete filename [/ORPHAN1/ir800-universalk9-bundle.SPA.159-3.M5]?
Delete flash:/ORPHAN1/ir800-universalk9-bundle.SPA.159-3.M5? [confirm]
%Error deleting flash:/ORPHAN1/ir800-universalk9-bundle.SPA.159-3.M5 (File not found)
ESNG_RTR21#bundle install flash:ir800-universalk9-bundle.SPA.159-3.M5.bin
ERROR: source file flash:ir800-universalk9-bundle.SPA.159-3.M5.bin does not exist or it's empty
Thanks in Advance
Do this:
test if show hidden
delete /f /r bootstrap:/ORPHAN1
Leo Laohoo
This means the IOS file is corrupt.
Most common cause is the download was interrupted and not completed.
I tried to copied thrice and result was the same , I used the same IOS for other Cisco 800 series router and its working
Not sure where is the problem ,
No, it is not.
Post the complete output to the command "dir flash:".
