IOS upgrade 2950
thomasandy32
After upgrading the IOS for crypto features,there is no command  IP HTTP SECURE-SERVER in IOS and also i can't do WEB Browsing  through HTTP??? though i have applied a command IP HTTP SERVER
The IOS uploaded to  c2950-i6k2l2q4-tar.121-22.EA13 also i tried with c2950-i6k2l2q4-tar.121-22.EA14 but the result is same.
Directory of flash:/
    2  -rwx         112  May 17 1993 08:28:51 +00:00  info
    3  -rwx        1048  Mar 01 1993 17:22:18 +00:00  multiple-fs
    4  -rwx         549  May 17 1993 08:38:58 +00:00  env_vars
    5  -rwx        1164  Mar 01 1993 00:00:26 +00:00  vlan.dat
    7  -rwx        3291  Mar 01 1993 00:06:32 +00:00  config.old
    8  -rwx     3722814  May 17 1993 08:32:13 +00:00  c2950-i6k2l2q4-mz.121-22.EA14.bin
    9  drwx        4416  May 17 1993 08:33:25 +00:00  html
  378  -rwx         112  May 17 1993 08:34:07 +00:00  info.ver
  336  -rwx        8838  Mar 01 1993 17:22:18 +00:00  config.text
  337  -rwx        1140  Mar 01 1993 17:22:18 +00:00  private-config.text
sh version
System image file is "flash:/c2950-i6k2l2q4-mz.121-22.EA14.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2950SX-48-SI (RC32300) processor (revision L0) with 19911K bytes of memory.
Processor board ID FOC1008ZCRW
Last reset from system-reset
Running Standard Image
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:17:0E:C9:FE:C0
Motherboard assembly number: 73-9103-04
Power supply part number: 34-0965-01
Motherboard serial number: FOC1006267R
Power supply serial number: DAB0936FPNB
Model revision number: L0
Motherboard revision number: A0
Model number: WS-C2950SX-48-SI
System serial number: FOC1008ZCRW
CLEI Code Number: CNMRV002RC
Top Assembly Part Number: 800-24115-03
Top Assembly Revision Number: A0
Version ID: N/A
Configuration register is 0xF
Hello Franco
For me while accessing http://192.168.10.1 also it is not working the page cannot be displayed error in internet explorer.
Check this out:
Unable to access a Catalyst switch with the web-based device manager or web interface utility
https://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K51046141
Franco
