IOS upgrade from 12.1(26)E3 to 12.3 (13)
sfanayei
Hi!
I an running Cisco 6006 WS-X6K-SUP2-2GE with WS-F6K-MSFC2 module. Currently It is installed software 12.1(26)E3 in my MSFC2 module. I would to upgrade mu IOS to the 12.3(13) vers. It seems that i can not finde any excat information regarding my case. How can I find out that 12.3(13) vers. can be installed in my Cisco 6006, and memeory and hardware is supprted. Tanks in advance!
Sfanayei
5 Replies 5
mohammedmahmoud
Level 11
Level 11
Please always use Cisco Feature Navigator to find information about platform support and Cisco IOS software image support:
http://www.cisco.com/go/fn
HTH,
Mohammed Mahmoud.
Hi again,
Tanks a lot for your reply, but i could not find somting i to use. Can you please provide me with more spesific info. based on information i was wrinting a bove? I will appreciate.
feature navigator may not have 6006 switch as its a EOS. You may talk to your vendor.
Hi Shahryar,
It is really simple, please use the supplied link and choose "search by platform", and then choose your platform " CAT6000-SUP2/MSFC2" and press continue, but i can see that the latest IOS available is 12.2(X).
HTH,
Mohammed Mahmoud.
Dear Mohammed,
Is it means that I can not install 12.3(13) in my MSFC2? Tnals again.
/Sfanayei
