IOS upgrade of 7613 router
tarnhundal
Hi All,
                I have to upgarde latest image of IOS on 7613 router ,I have to implement SLA on this and currently its not supporting . I m posting image of current IOS . I think its a 7200 router image.plz help me to upgrade it.
sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Versio        n 12.2(33)SRA1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 01-Sep-06 15:24 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
GATEWAY uptime is 1 week, 4 days, 20 hours, 2 minutes
Uptime for this control processor is 1 week, 4 days, 20 hours, 1 minute
Time since GATEWAY switched to active is 1 week, 4 days, 20 hours, 0 minute        s
System returned to ROM by  power cycle at 14:13:26 gmt Fri Jul 24 2009 (SP by po        wer on)
System restarted at 18:37:35 gmt Mon Jan 11 2010
System image file is "bootdisk:s72033-advipservicesk9_wan-mz.122-33.SRA1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7613 (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID SAL1050B3P6
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4 SIP-200 controllers (4 FastEthernet)(88 E1)(4 POS).
1 SSC-400 controller (1 IPSEC).
2 Virtual Ethernet interfaces
4 FastEthernet interfaces
6 Gigabit Ethernet interfaces
61 Serial interfaces
88 Channelized E1 ports
4 Packet over SONET interfaces
1 SDCC interface
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thanx and Regards,
Taran
19 Replies 19
Giuseppe Larosa
Hello Taran,
you can use feature navigator at
http://www.cisco.com/go/fn
search by feature: type SLA
several items are listed, for example
FHRP - Enhanced Object Tracking of IP SLAs
by selecting as platfrom C7600 SUP720/MSFC3 you can find out a list of possible IOS images.
Taking last subversion of penultimate version a possible choice can be:
c7600s72033-advipservices-mz.122-33.SRD3.bin
take the equivalent of this for your image and you should be fine.
Be aware that several other uses of IP SLAs are listed in FN
Hope to help
Giuseppe
You can move to 12.2.SRE, it has some new features for EEM and IP SLA
          Thanx for reply to both of u.Recently I have upgraded 7206 IOS image to all routers but here i m bit confused because the keyword in IOS image of 7600 is 7203, I didnt get he meaning for this.If I m using 7600 image the what 7203 stands for ? second is last time my IOS upgradation has been done 3 years ago, so I need a IOS image which should work for SLA also for other latest features.I hope you will send me details about it.
thanx and regards,
Taran
Hello Taran,
Don't let that number confuse you.  The numbering for all IOSs for 6500 has 72033 in it. For example, below IOS is the latest for 6500 switches and NOT for 7200.
s72033-adventerprisek9_wan-vz.122-33.SXI3.bin
For 7600 routers, here is the latest image on CCO
c7600rsp72043-adventerprisek9-mz.122-33.SRE.bin
Reza
72033 and 72043 both shows the type of your Supervisor engine, 72033 is for SUP720-3B and 72043 is for RSP720-3BXL,
as per your show version, you would need: c7600s72033-adventerprisek9-mz.122-33.SRE.bin, you can download it from CCO.
HI ,
            thanx for reply. I think , I need 72043 image because we have 3bxl sup eng.I wll upgrade it and then tell you about it in detail.
Thanx and regards,
Taran
              I have to also upgrade IOS image for 6513. Thanx you have provided me these images. Plz let me know that as I have done with 7206 router , will this process be same for these devices like 7600 and 6500 ,means First ,I wll copy image to disk then replace the path with current image then after saving the image I wll reload it. Am I right ? Plz let me know about it.
thanx and regards,
Taran
copy the images to disk, and then remove old "boot system flash" command and then re enter with new image file. and reload ahaa
dont forget to to use verify comand after copying the image, it will tell you if you are using correct image for your platform or not.
Hi Yasir,
              I was doubtful about this method . thanx for reply. Tell me one more thing that  I m using sup eng 3BXL and I want 72043 image but i m unable to download it and everytime it shows just 72033 according to my platform,I m using MSFC3. So what to do upload this image ?
thanx and regards,
Taran
as per your show version you should use 72033, 72043 is for RSP your router wont load it.
HI,
            I have multiple options here for 6500 switch,  I think I should install CAT6000-SUP720/MSFC3 rather CAT6000-VS-S720-10G/MSFC3.what u say ? For 7600 I m going to install c7600s72033-adventerprisek9-mz.122-33.SRE.bin.
thanx and regards,
Taran
Hi Yasir,
                      I saw that SRE image will take much memory than SRD as suggested by guislar. Now what u say , what should I do now ? I m bit confused about image choice and its upgradation . And also tell me that what should I do for ISSU ? Should it be supported on previous version of IOS . I checked it and current version is not showing anything about ISSU .plz let me know about it in detail.
Thanx and regards,
Taran
             I have seen this SRE image will take much memory as compared to others , You have suggested good idea about SRD3. This will be useful for my all needs like SLA. Plz let me know something about bootloader. Should I have to chang it or not ?Yasir also suggested good idea about ISSU. you both plz help me to sort out this issue and load IOS with minimum delay.
Thanx and regards,
Taran
You can go with SRD3 too, it supports ISSU too.
