IOS upgrade of 7613 router
tarnhundal
Hi All,
                I have to upgarde latest image of IOS on 7613 router ,I have to implement SLA on this and currently its not supporting . I m posting image of current IOS . I think its a 7200 router image.plz help me to upgrade it.
sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Versio        n 12.2(33)SRA1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 01-Sep-06 15:24 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
GATEWAY uptime is 1 week, 4 days, 20 hours, 2 minutes
Uptime for this control processor is 1 week, 4 days, 20 hours, 1 minute
Time since GATEWAY switched to active is 1 week, 4 days, 20 hours, 0 minute        s
System returned to ROM by  power cycle at 14:13:26 gmt Fri Jul 24 2009 (SP by po        wer on)
System restarted at 18:37:35 gmt Mon Jan 11 2010
System image file is "bootdisk:s72033-advipservicesk9_wan-mz.122-33.SRA1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7613 (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID SAL1050B3P6
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4 SIP-200 controllers (4 FastEthernet)(88 E1)(4 POS).
1 SSC-400 controller (1 IPSEC).
2 Virtual Ethernet interfaces
4 FastEthernet interfaces
6 Gigabit Ethernet interfaces
61 Serial interfaces
88 Channelized E1 ports
4 Packet over SONET interfaces
1 SDCC interface
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thanx and Regards,
Taran
19 Replies 19
Hi Yasir,
                     Thanx for reply. To use the service of ISSU , I have to copy IOS on both sup both active and standby ? Am I right ? Can u plz elaborate me in detail about 7613 ISSU method. I wll be thankful to u.
regards,
Taran
Please Go through this Document in Detail, and make sure you donot miss any thing
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/efsuovrw.html
Hi Yasir,
                        Thanx for reply. Actually I have this link and also downloaded it but the critical thing is I m bit afraid about it because its our core router and even a single mistake can create big problems and I dont want to be get fired from Co. I will test it after 15 days and will tell u the results.
Taran
Haha, Yeh its hell lot of risk in it, i remember when i did it first time it worked and i jumped with my collegues, everyone was congratulating me because it was my idea and i fought for it to my higher management, so i was very happy, because it only created 10 seconds of downtime and our core router was upgraded, but very next moment, core router restarted because if incompatiblity of both active and backup images, and it caused nearly 15 minutes of downtime because of ISSU 's wrong variables.
Thats why i would say that you must do a complete research before doing it, you can take help direct from CISCO TAC if you have a support contract.
HI,
                 Haha. It was a really interesting story.I hope I wll do better without any problem. I wll tell u about testing and if possible take more help from u .
regards,
Taran
