IOS Version Support
saman.perera
I am trying to configur a 3845 with VWIC2-2MFT-G703, HWIC-1FE Interface cards. Can someone tell me the correct feature pack for these modules please
mohamed.khadr
IOS 12.4.5a LT.
smothuku
Level 7
Level 7
Hi Saman ,
Check whether the 3845 router supports HWIC-1FE or not.
While checking for IOS i noticed that in the field of HWIC , i found only ethernet and gigbit ethernet cards, not Fastethernet cards.
Satish
The HWICs mentioned are supported on the 3800 platforms as per the link below (though not mentioned in the 3800 data sheet)
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd80581fe6.html
Any 12.4T image would work for you
HTH,rate if it does
Narayan
