IOS-XE 16.8.x line vty 'vrfname'
johnlloyd_13
Level 9
Level 9
hi,
i noticed the 'vrfname' under the line vty. i checked it was recently introduced in IOS-XE 16.8.x.
i usually use 'vrf-also' for our MGMT VRF and haven't seen anyone use 'vrfname' that much per my google search.
my question is, what's the difference between the 'vrf-also' and 'vrfname'? is 'vrfname' more secure?
what are some use case examples for the 'vrfname'?
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bbdsl/configuration/xe-16-11/bba-xe-16-11-book/bba-xe-16-8-book_chapter_0100101.pdf
(config)#line vty 0 4
(config-line)#access-class acl_VTY_ACL in ?
  vrf-also  Same access list is applied for all VRFs
  vrfname   Access list is applied for given VRFs
  <cr>      <cr>
8 Replies 8
Seb Rupik
Hi there,
The decision to allow all VRFs access to the VTYs or limit it to just one depends on your topology and security posture. Certainly vrf-also is convenient, but if you are operating a multi tenant environment then it would make sense to limit access to the management plane to just one VRF, ie, the L3 domain which contains your management VLAN.
cheers,
Seb.
balaji.bandi
Do not want to re-invent the wheel :
good explanation here :
https://community.cisco.com/t5/switching/vty-access-class-vrf-also-question/td-p/2528048
BB
johnlloyd_13
Level 9
Level 9
hi balaji,
i'm aware of the 'vrf-also' and use it in our environment. my question is regarding 'vrfname' if has the same purpose and what's the main difference between the two.
i don't see it commonly used since it's relatively new.
I have the opposite experience and always use 'vrfname Mgmt-vrf' as switches are connected via the out of band gi0/0 switchport.
vrfname is useful as it allows you to explicitly list the VRFs you want to have access instead of opening the flood gates and using vrf-also, as you eluded to in your first post, this should be considered more secure.
cheers,
Seb.
adding @Seb Rupik  comment...
Commands are self explanatory. If you have more VRF ( VRF-also works) - if you looking Granular 1 VRF - VRFNAME should do the job
Make sense ?
BB
hi balaji,
is using 'vrf-also' tied to the default 'Mgmt-intf' VRF, which is applied to the dedicated OOB management port?
yes mgmt vrf should cover technically. (if that is the only VRF available in your network, i prefer to go with vrfname
BB
I know I am necro-ing an old thread here, so sorry about that. My process for routers handling untrusted traffic (like internet routers) prior to the support for being able to name a specific vrf in the access class on the vty's was to put the management traffic in the global routing table and then untrusted traffic in a vrf. That way when I specified an access class without the 'vrf-also' keyword then all traffic from vrf's was blocked. I a context where management traffic is in 'Mgmt-intf', can I specify an access class for that vrf that permits certain hosts, and then another access class without a vrf keyword that denies all traffic from the global routing table? The routers I have with this now are remote and I don't want to lock myself out.
