05-20-2016 11:54 AM - edited 03-05-2019 04:03 AM
When I do trace routes to this nexus switch, it lists at the end the originating IP, no matter from what other router or switch I am using to do the traceroute. This is an example:
Ash-Core-SW1#trace 10.240.103.254
Tracing the route to 10.240.103.254
VRF info: (vrf in name/id, vrf out name/id)
1 10.1.10.253 0 msec 0 msec 8 msec
2 10.1.1.253 0 msec 0 msec 0 msec
3 10.1.7.1 8 msec 9 msec 0 msec
4 10.202.1.50 50 msec 59 msec 50 msec
5 10.1.10.254 50 msec 58 msec 51 msec --> this is the interface originating the trace
Ash-Core-SW1#sh ip int bri
GigabitEthernet1/0/22 10.1.10.254 YES NVRAM up up
Any help is highly appreciated
Thank you
05-20-2016 03:01 PM
That is normal for Cisco IOS.
05-22-2016 06:48 AM
Hi, Ernesto,
There seems some looping issue, Can you please show us the full traceroute report?
Sheshu.
05-23-2016 06:04 AM
Thank you for your reply, I am sorry I am not following you, what do you mean by full traceroute report? Just in case, here is an extended trace:
Ash-Core-SW1#trace
Protocol [ip]:
Target IP address: 10.240.103.254
Source address: 192.168.1.254
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
1 10.1.10.253 0 msec 0 msec 0 msec
2 10.1.1.253 0 msec 17 msec 9 msec
3 10.1.7.1 0 msec 8 msec 0 msec
4 10.202.1.50 51 msec 50 msec 50 msec
5 192.168.1.254 59 msec 50 msec 50 msec
05-24-2016 07:20 AM
Your second traceroute is different from the first one, please compare 5th hop in both.
In first, it is
In second, it is
Second trace is what it should be and looks correct, did anything change?
Sheshu.
05-24-2016 11:02 AM
Hello, no, I just used a different source IP for the trace
05-24-2016 09:47 AM
What version is this?.
05-24-2016 10:59 AM
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.05SE RELEASE SOFTWARE (fc1)
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24TS 03.03.05SE cat3k_caa-universalk9 INSTALL
