IP OSPF HIDDEN COMMAND??
David Salazar
Hi, Everybody.
could someone tell me something about the command?
MBO-RT-02#sh ip ospf de
            OSPF Router with ID (192.168.167.1) (Process ID 1)
    Area BACKBONE(0)
    Intra-area Route List
*   192.168.161.0/24, Intra, cost 1, area 0, Connected
      via 192.168.161.6, FastEthernet0/0.1
MBO-RT-02#
MBO-RT-02#
MBO-RT-02#sh ip ospf ?
  <1-65535>            Process ID number
  border-routers       Border and Boundary Router Information
  database             Database summary
  flood-list           Link state flood list
  interface            Interface information
  max-metric           Max-metric origination information
  mpls                 MPLS related information
  neighbor             Neighbor list
  request-list         Link state request list
  retransmission-list  Link state retransmission list
  rib                  Routing Information Base (RIB)
  sham-links           Sham link information
  statistics           Various OSPF Statistics
  summary-address      Summary-address redistribution Information
  timers               OSPF timers information
  traffic              Traffic related statistics
  virtual-links        Virtual link information
  |                    Output modifiers
  <cr>
Is a Hidden Command?
David Salazar
Hi David
This is undocumented command by cisco .
This command shows you the lsas which have been deleted from
consideration.  as i don't have ospf running, i can't ascertain whether
this is lsas which were taken out of consideration by the SPF algorithm
or by other means.
ctalkb#sh ip ospf delet
  AS System  N
    Area BACKBONE(0)
    ROUTER and NETWORK LSDB delete list
      Dest: 172.16.0.1, Type: 0, Metric: 1, ADV RTR: 172.16.0.1
      Path:
        gateway 172.16.0.1, interface Loopback0
    SUMMARY NET and ASBR LSDB delete list
    TYPE-7 EXTERNAL LSDB delete list
Please refer the below link for Cisco undocumented command & there detail
http://www.nthelp.com/cisco_undoc.htm
Chetan Kumar
Reza Sharifi
Hi David,
Yes, it is a hidden command.  "de" is short for delete-list.
show ip ospf delete-list
It is documented here:
http://www.elemental.net/~lf/undoc/#d0e530
Reza
