Policy Based Routing
tmcmurray
I have a site that offers two circuits.  One is a 28mbps dynamic VPN connection, the other is a 3mbps point-to-point multilink.  My issue is that I would like all voice and video traffic to use the P2P and all other traffic to use the VPN.  If the VPN goes down, I would like all traffic to traverse the P2P and vice cersa if the P2P goes down.
How do I set up PBR using protocol as my method of routing?  I understand PBR using source/destination criteria.
Mohamed Sobair
Level 7
Level 7
PBR can also use a protocol for source of routing, you just need to include which protocols in the Extended Access-list of the matching traffic.
example:
interface f0/0
ip policy route-map policy
ip address x.x.x.x y.y.y.y
route-map policy permit 10
match ip address 100
set ip next-hop x.x.x.x
access-list 100 permit (TCP/UDP) source destination eq ports
Is this what you are lookin for?
Mohamed
Mohamed Sobair
Level 7
Level 7
example:
interface f0/0
Mohamed
