Ip-precedence flash-override
I found, in a router configuration, one route-map that "set ip precedence flash-override", but what means?
6 Replies 6
Mark Elsen
 Ref : https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3s/iri-xe-3s-book/iri-qos-policy-prop-via-bgp.html
 - Look for the string 'precedence'  apparently it relates to QoS
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Yeah, I know that it's about a QoS....but I don't understand "flash-override" what it does :)
 - As you have the command available on your device you can go into configuration mode and enter set ip precedence ? . A list of options will be presented where then flash-override will be listed with a short description of what it does.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I think 'flash-override' equals IP precedence value 4. Check table 6.2 in the attached document...
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus1000/sw/4_0/qos/configuration/guide/nexus1000v_qos/qos_6dscp_val.html#21470
Deepak Kumar
Duplicate question. Already shared details.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Joseph W. Doherty
As others have already noted, it sets the first 3 bits, of the packet's ToS byte, to (binary) 100. BTW, so does setting DSCP to CS4, AF41, AF42 and AF43. The latter, i.e. setting DSCP, also sets the next 3 ToS bits to some value, while IPPrec does not change them.
Setting ToS bits might be seen on a pretty old device that doesn't support DSCP, or a configuration never updated, or perhaps, some clever "trick" in only wanting to reset/set just those first 3 bits.
Also BTW, the "trick" might be more useful for checking the DSCP group. For example, rather than
match ip dscp CS4 AF41 AF42 AF43
you might see
match ip precedence 4
