ip route noob question
chrisirene
hi guys, this command tells what? ip route 192.168.1.16 255.255.255.0 10.1.1.2
and ip route 0.0.0.0  0.0.0.0.0 192.168.1.17 tells what also? thanks.
3 Accepted Solutions
u1kumar2002
     ip route 192.168.1.16 255.255.255.0 10.1.1.2---> this statement is wrong...  The network is not in correct format... if you configure this command in router it will show you error - Inconsistent address and mask. it should be --- ip route 192.168.1.0 255.255.255.0 10.1.1.2 , means remote network 192.168.1.0/24 is accessible via 10.1.1.2.
ip route 0.0.0.0  0.0.0.0.0 192.168.1.17 : this statement is wrong, it should not be 5 octet in mask. It should like this 0.0.0.0 0.0.0.0 192.168.1.17 this is a default route means that all packet should go to 192.168.1.17.
Hope this information will help you
Do rate for helpful posts...
Uttam
http://www.startnetworks.blogspot.com/
k_srinadh
Wrong Usage : ip route 192.168.1.16 255.255.255.0 10.1.1.2
Correct Usage: ip route 192.168.1.0 255.255.255.0 10.1.1.2
In that ip route
We are routing particular network (192.168.1.0) to go out thro/Via (10.1.1.2) this path.
Wrong Usage : ip route 0.0.0.0  0.0.0.0.0 192.168.1.17
Correct Usage : ip route 0.0.0.0 0.0.0.0 192.168.1.17
this is called Default routing
also known as the gateway of last resort, is the network route used by a router when no other known route exists for a givenIP packets destination address
Hope this helps.
Srinadh
vinod.agrahari
Hi Chris,
The first command:
Ip route 192.168.1.16 255.255.255.0 10.1.1.2 is incorrect and will return an error message of bad subnet mask as we are using hop address in place of network address.
The correct configuration of static route should follow the following format:
Ip route and probably we can use it:
Ip route 192.168.1.0 255.255.255.0 10.1.1.2
This is what we call it static routing and in above corrected scenario, all the traffic of network 192.168.1.0 will go via interface 10.1.1.2
In Second command:
Ip route 0.0.0.0 0.0.0.0 192.168.1.17 is wrong and will return incomplete command error as we are using five zero’s in the wild mask option instead of four zero.
The correct configuration for default routing should follow following format:
Ip route 0.0.0.0 0.0.0.0 and probably we can use like this
This is what call gateway of last resort and will often configure in the Stub Network where gateway of last resort is not set.
Vinod Agrahari
u1kumar2002
Uttam
k_srinadh
In that ip route
Hope this helps.
Srinadh
vinod.agrahari
Hi Chris,
The first command:
In Second command:
Vinod Agrahari
chrisirene
thanks guys, for your help
