ip routing exercise in my attachement
Hello everyone ,
I have my infrastructure in my attechement , but what is the ip routing for my server A and D ?
Can you check my answer please ? thank youuu
Server A
DestinationmaskRouterinterface
192.168.2.0255.255.255.0192.168.1.1 (R12)eth0
192.168.8.0255.255.255.0192.168.8.1 (R13)eth0
192.168.9.0255.255.255.0192.168.8.1(R13)eth0
Server D :
192.168.1.0255.255.255.0192.168.8.254(R13)eth1
192.168.9.0255.255.255.0192.168.8.1(R34)eth0
192.168.2.0255.255.255.0192.168.8.254(R13)eth1
where is Server D ? And what is your question exactly ?
Hello George ,
Server D it's my host D ,
I would like to define routing table of my host D
,) thanx you
Hello
As it stands without any IGP or static routing applied:
Host D with have a connected route and arp entries for itself, R13 - R34 192.168.8..0 /24 via eth0
SRV A with have a connected route and entries for  itself, SRV B, R12 -R13  192.168.1.0 via eth0
SRV B with have a connected route and entries for  itself, SRV A, R12 -R13  192.168.1.0 via eth0
R12 will have a connected route for 192.168.1.0/24 via eth 1 & 192.168.1.0/24 via eth 0 with arp entries for itself  R13, SRV A,B
R13 will have a connected route for 192.168.1.0/24 via eth 0 with arp entries for itself, R12, SRV A,B & connected interface for 192.168.8.0/24 via eth 1 with arp entries for Host D, R34.
Thus the above will allow communication between host A-D via 192.168.1/0/24
Kind Regards
Paul
Yes thank you for you answer,
In your reply with R12, we have 192.168.2.0 via eth1 and 192.168.1.0 via eth0
I don't undestand your routing table of server A , my table is similar ?
Thanx you
