IP SLA (icmp) not resetting
joneswill
I have two sla monitors setup (in lab at the moment) to ping two external IP addresses.  If both the addresses fail to respond, I want to change my default route to use 172.16.68.37.   If/when either of the destination IP addresses come back up, I want the original default route 172.16.68.3 to be preferred instead.
Here is my relevant config:
ip sla monitor 1
type echo protocol ipIcmpEcho 195.155.0.1 source-interface FastEthernet0/0
frequency 10
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho 125.200.1.1 source-interface FastEthernet0/0
frequency 10
ip sla monitor schedule 2 life forever start-time now
track 1 rtr 1 reachability
delay down 30 up 30
track 2 rtr 2 reachability
delay down 30 up 30
track 3 list boolean and
object 1 not
object 2 not
ip route 0.0.0.0 0.0.0.0 172.16.68.37 track 3
ip route 0.0.0.0 0.0.0.0 172.16.68.3 50
Ok - so what happens?
If I take one of the external IP's down nothing changes = good
If I take both of the external IPs down, the existing default route is changed to use 172.16.68.3 = good
My problem is - when one (or both) of the external IPs come back, the SLA config appear not to detect this - an output of "show track" shows that for both monitors, the reachability is down.
Any ideas what I'm doing wrong?
cheers
margalla
Have you configured PBR so the SLA probes take the path you are actually trying to test?
See Configuring the Routing Policy for Reliable Static Routing Backup Using Object Tracking
If not then the route to your external addresses follows whatever your current default route is and you don't want that.
