IP SLA ( IP Service Level aggremnet ) problem ?
mohdsaad1
Dear Cisco Professional
My Scenario :
I have 3 Cisco Routers as following :
G.SHDSL Router : Cisco 3845 with
ISDN and Branch Router : Cisco 2811
How My Network works :
Branch Router has two type of connection ( First one : G.SHDSL link work as Main link and the other one ISDN Link work as Backup link )
when main link goes down the ISDN link goes up ...
( Note : i applied IP SLA with tracking ) ...
My Problem :
i want to delete default route from ( G.SHDSL Router )
0.0.0.0 0.0.0.0 dialer 3
- Note : My network works properly with these configuration but when i delete the default route 0.0.0.0 0.0.0.0 dailer3 , my network goes down ( Failover technique not works )
in general :
My network should works with two these router :
ip route 192.168.6.0 255.255.255.0 172.113.2.1 10
ip route 192.168.6.0 255.255.255.0 Dialer3 track 1
Please advice me what should i Do.
Look at atched file ...
Nikita Singh
From what I see this is the track you have configured,
ip sla 1
icmp-echo 10.10.10.2 source-interface Dialer3
timeout 1000
You are tracking 10.10.10.2 and I guess you do not have a route to 10.10.10.2 but the default route. So, when you remove that defalut route the track goes down. You have configured failover only for these routes:
Not for the defalut route. Not sure what your requirement is but it is working as expected from the config you have.
