please help, trying to set up Dual Wan load balancing on a 1811 cisco router
jeremy.clark
I have a cisco 1811 router with two wan ports and I would like to set up load balancing.
I have everything working on one wan port but I am having trouble setting up the second and enabling load balancing.
What is the process involved in setting this up?
thank you!!
Jeremy Clark
Nikita Singh
You just need two routes pointing out through the 2 wan interface. (assuming you are using static routes).
ex:
ip route 0.0.0.0 0.0.0.0
show ip route for a destination will show two paths. The path with * will be the best route. By default it will do per destination load balancing (cef enabled)
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
