Problem configuring VWIC2-1MFT-T1/E1 on 2921 Router
slctest123
Greetings all.  I'm new to the CISCO community and need help with configuring a VWIC2-1MFT-T1/E1 card on a 2921 router in my lab.  I've followed the configuration steps for the card, but when I run the sh controller command, it shows 'down'.  My configuration steps are shown below.  Any help would be appreciated.
Thanks in advance
--Roland
card type t1 0 2
controller T1 0/2/0
framing SF
clock source internal
linecode ami
cablelength long 0db
ds0-group 0 timeslots 1-6 type e&m-immediate-start dtmf dnis
ds0-group 1 timeslots 7-12 type e&m-wink-start dtmf dnis
ds0-group 2 timeslots 13-18 type fxs-ground-start
ds0-group 3 timeslots 19-24 type fxs-loop-start
mvsheik123
Level 7
Level 7
have you connected the T1 port to service provider or if in lab, a simulated environment? You need the physical connection with proper configs to bring up the T1.
hth
MS
mvsheik123
Level 7
Level 7
hth
MS
Thank you for your response.  Yes, I did have a T1 connected.  My problem was that I needed a cross-over cable between our lab's T1 cable and the router.
--Roland
