IP SLA on Cisco Router
agha talha
HI All,
we are configuring the IP SLA on Cisco Router,
we have two Internet links and one router.
I am able to reachable the internet from my PC via 2nd ISP, when I unplug the 2nd ISP cables, now the Primary static route is not showing, and the primary ISP internet from PC is not working..
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
interface FastEthernet0/0
description Inside Interface - LAN
ip address 10.213.57.20 255.255.255.0
ip nat inside
duplex full
interface FastEthernet1/0
no ip address
shutdown
duplex full
interface FastEthernet2/0
no ip address
shutdown
duplex full
interface FastEthernet3/0
no ip address
shutdown
duplex full
interface FastEthernet4/0
description PTCL
ip address 117.20.18.82 255.255.255.248
ip nat outside
shutdown
duplex full
interface FastEthernet5/0
no ip address
duplex full
interface FastEthernet6/0
description MPLS
ip address 182.176.4.92 255.255.255.248
ip nat outside
duplex full
ip nat pool BACKUP 182.176.4.89 182.176.4.94 netmask 255.255.255.248
ip nat pool PRIMARY 117.20.18.81 117.20.18.86 netmask 255.255.255.248
ip nat inside source route-map BACKUP interface FastEthernet6/0 overload
ip nat inside source route-map PRIMARY interface FastEthernet4/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 117.20.18.81 track 1
ip route 0.0.0.0 0.0.0.0 182.176.4.89 track 2
ip access-list extended NAT_BACKUP
permit ip 10.213.57.0 0.0.0.255 any
ip access-list extended NAT_PRIMARY
ip sla 1
icmp-echo 117.20.18.81 source-interface FastEthernet4/0
threshold 2
timeout 1000
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 182.176.4.89 source-interface FastEthernet6/0
threshold 1000
timeout 1000
frequency 5
ip sla schedule 2 life forever start-time now
route-map BACKUP permit 20
match ip address NAT_BACKUP
route-map PRIMARY permit 10
match ip address NAT_PRIMARY
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Router(config-if)#
Router(config-if)#
Router(config-if)#
Router(config-if)#end
Router#
Router#
Router#sh ip nat
*Feb 15 20:29:03.763: %SYS-5-CONFIG_I: Configured from console by console tr
Router#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 182.176.4.92:1024 10.213.57.21:6004 8.8.8.8:6004 8.8.8.8:1024
icmp 182.176.4.92:1025 10.213.57.21:6260 8.8.8.8:6260 8.8.8.8:1025
icmp 182.176.4.92:1026 10.213.57.21:6516 8.8.8.8:6516 8.8.8.8:1026
icmp 182.176.4.92:1027 10.213.57.21:6772 8.8.8.8:6772 8.8.8.8:1027
balaji.bandi
There are different ways to achive this to failover since you have only 1 Subnet in the Lan, (personally Route-map not much effective)
Route-map we use only when you like to Traffic steering one over other to utlilise both the links based on source or based on destination.
you still like to use Route-map
you need add below interface command to the config :
set interface FastEthernet6/0
set interface FastEthernet4/0
what is the reason you added below : (you would like to use this Pool for NAtting ?)
other methods check below example : (bottom you see example for single subnet)
https://www.balajibandi.com/?p=1643
BB
