Policy based routing issue
hfakoor222
Doing a lab ~
When applying an ACL to policy based routing it is working as intended. When applying a prefix-list that is supposed to be matching the same subnet it is not.  R3 is applying PBR.
R4 has two loopback:
L4:  192.168.4.1/25
L5: 192.168.4.128/25
interface Loopback4
description R4 LAN A
ip address 192.168.4.1 255.255.255.128
interface Loopback5
description R4 LAN B
ip address 192.168.4.129 255.255.255.128
With prefix list it seems to be matching everything and everything is routed to next hop, where I am only wanting to set next hop for Loopback 5:
Router R3
interface Serial0/2
description R3 --> R4
bandwidth 64
ip address 172.16.34.3 255.255.255.248
ip policy route-map ROUTE_LAN2
serial restart-delay 0
ip prefix-list R4_LAN2 seq 15 permit 192.168.4.128/25 le 32
route-map ROUTE_LAN2 permit 5
match ip address prefix-list R4_LAN2
set ip next-hop 172.16.13.1
With this configuration both L4 and L5 get next hop applied in PBR:
Now I try ACL and it does what I want:
interface Serial0/2
bandwidth 64
ip policy route-map R3-to-R1
route-map R3-to-R1 permit 10
match ip address PBR-ACL
R3#show access-lists
Standard IP access list PBR-ACL
10 permit 192.168.4.128, wildcard bits 0.0.0.127 (12 matches)
Here is the result I get what I want:
I revert to prefix-list PBR:
interface Serial0/2
bandwidth 64
R3#show ip prefix-list
ip prefix-list R4_LAN2: 1 entries
Result is not what I want:
I seem to be misapplying the prefix list., at least this is my opinion.
Any suggestions on what i may be doingt wrong with the prefix list and how to fix it?
Hello @hfakoor222 ,
prefix-lists have been introduced to perfom route filtering they act on the control plane and not on the data plane.
PBR works on the data plane so you should use ACLs not prefix-lists  for the match condition
Hope to help
Giuseppe
12 Replies 12
PBR uses the functionality of Standard/Extended ACLs. I don't believe there is support for a prefix list. My best guess is if you match on a standard ACL you matching on the source (since that all you can supply) and if you use an extended ACL you're matching on source/destination. With a prefix list you're just identifying a network, not a source or destination. The router wont know how to handle that. Prefix lists are usually meant to identify network for filtering in routing protocols and not match on a source/destination of anything.
Hope that helps.
-David
balaji.bandi
In addition to @David Ruess
Generally prefix-list used to match most cases in Routing protocols where it required to match conditions to ge or le conditions.
PBR you can use prefix list but its not that as effective compare to ACL standard and extended where you need to match the subnets
if you looking only to match the traffic of loopback you can use /32 subnet instead of le 32  or just match the host entry - you can try and test it.
Also we use PBR to match some time based on the destination we use next hop, not always source only.
BB
https://www.ciscopress.com/articles/article.asp?p=1613547&seqNum=4
According to ciscopress you can use both, this time pbr not prefix filter and we common use acl not prefix for pbr but anyway
Let me check it
MHM
show route-map  <pbr name>
Debug ip policy
Share the output of both command in both case using acl and using prefix list
MHM
I receive error when try apply pbr under the interface,
so I seem that not all Cisco IOS support prefix list as match in PBR
MHM
Giuseppe Larosa
Hello @hfakoor222 ,
The prefix-list matches a prefix in the IP routing table regardless of user traffic flows, for this reason the IP ACL is the right match tool for PBR applications.
With ACL the user traffic is checked against the ACL permit statement permitted traffic is redirected.
Hope to help
Giuseppe
For anyone wondering
I tried changing the prefix-list to ip prefix-list to
ip prefix-list R4_LAN2 seq 15 permit 192.168.4.129/25
erased it and then
ip prefix-list R4_LAN2 seq 15 permit 192.168.4.129/32
same result
then added a seq 10to deny Loop 4:
ip prefix-list R4_LAN2 seq 10 deny 192.168.4.1/32
All the same results
then
clear route-map counters ROUTE_LAN2
and erased the prefix list so all it had was implicit deny all same behavior:
R4#trace 192.168.1.1 source L5
Tracing the route to 192.168.1.1
VRF info: (vrf in name/id, vrf out name/id)
1 172.16.34.3 25 msec 31 msec 30 msec
2 172.16.13.1 62 msec 59 msec 61 msec
R4#
R4#trace 192.168.1.1 source L4
1 172.16.34.3 24 msec 29 msec 28 msec
2 172.16.13.1 62 msec 77 msec 80 msec
R3#show route-map
route-map R3-to-R1, permit, sequence 10
Match clauses:
ip address (access-lists): PBR-ACL
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map ROUTE_LAN2, permit, sequence 5
Match clauses:
Set clauses:
Policy routing matches: 12 packets, 384 bytes
It seeming like in all cases it wasn't matching my prefix lists. Strange to me.
Use prefix-list in route-map
The  remove ip policy route-map and add it again do you see any error message?
I think you add pbr under interface then config pbr wit match prefix-list
It seem accpet by router but in real it not.
MHM
Hello @hfakoor222 ,
Hope to help
Giuseppe
@hfakoor222 did you get error when you add PBR under interface ?
MHM
No error, it just did not work right. What Mr. larosa mentioned with prefix list being in control plane may be the issue.
No error, the PBR just wasn't working right.
Patryk Nieborak
Hey,
Just to add to previous posts - on IOS-XE 17.15.1a, for IPv4 PBR you'll see error message when trying to attach route-map containing prefix-list in matching condition, however for IPv6 PBR you won't. IOS allows this configuration, but PBR will start matching all traffic. You need to use IPv6 ACL as RM matching condition for IPv6 PBR to work properly.
