IP SLA ROUTE PROBLEM VRF
dmbnex
Hi All,
Im trying to get a very basic operation of ip sla with reachibility tracking to trigger route decision between two links.
Link 1 - Primary ISP vlan201- is a dhcp link - I need to be able to track an address on internet
Link 2 - Backup LTE link - vlan31 - static ip addressing
both links are terminated in a vrf "inet", there is aslo basic bgp in use locally on the router
what happens is that ip sla comes up with default gw over Link1 but when it goes down the default route is not removed
when I manually remove the default route ip route vrf inet 0.0.0.0 0.0.0.0 Vlan201 dhcp 251 the link 2 route takes over, enabling the link 1 does nothing and when manually pinging the 1.1.1.1 it does not answer when it should.
I have tried removing interface from primary route without it helping.
it may seem that bgp has something to do with this but I'm no sure
ip sla configuration:
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 1.1.1.1 source-interface Vlan201
vrf inet
frequency 15
ip route vrf inet 0.0.0.0 0.0.0.0 10.11.12.2 253
interface Vlan201
vrf forwarding inet
ip dhcp client route track 1
ip address dhcp
end
bgp config:
address-family ipv4 vrf inet
redistribute connected
redistribute static
default-information originate
exit-address-family
vrf:
vrf definition inet
rd 65000:1
route-target export 65000:1
route-target import 65000:1
route-target import 65000:2
address-family ipv4
exit-address-family
Have you guys seen same behavior, or am I just blind and cant see the obvious in front of me?
Equipment in use is Cisco ISR C1100 router with IOS-XE 17.6.5
23 Replies 23
Hello @MHM Cisco World
run lab and spent 1 hours, there is no solution for track under interface and DHCP with VRF aware
can you elaborate- you saying dhcp client route track isn’t applicable when the interface is within a vrf?
Kind Regards
Paul
Yes Correct,
the track never become UP always it down.
first I suspect with
ip sla auto discovery <<- command add for track under interface
but even with this command the track is Down always.
@dmbnex
please add ip sla auto discovery <<- and check again
Hello
2 probable reasons for that
- you have to always apply the dhcp client route track BEFORE you enable dhcp on the interface
- your simulation software isn’t applicable
Last you should not require ipsla auto discovery
Kind Regards
Paul
there is no ip sla auto discovery command in ios-xe 17.6.5
I have this applied already
ip dhcp client request route <- is default behavior and is not necessary with ip address dhcp command in my case
ip address dhcp is different than ip dhcp client,
the ip dhcp clinet will automatic add defautl route toward next-hop, this next-hop is the default-router you config in dhcp server local pool.
this default route will add with 254 and it to high.
so with ip add dhcp client default-route distance  we can change this value.
Yes, and thanks,
I'm aware of this but the problem with this dhcp link(which I do not have control over) is that sometimes interface stays UP(and thus the ip/gw) but upstream router actually is not forwarding traffic.
in this case the route will still have higher priority and backup will never take over.
I will test more tomorrow, Im also thinking about scripts, maybe there is something may be automated when a log log entry is created.
You are right, totally right.
but we face issue of static route with egress interface without next-hop
the router refuse this static route.
so as you mention EEM, I have one solution BUT this need more work.
my solution is using track in global mode and make VRF leaking between global-VRF and then use this track in EEM to shut no shut the DHCP interface.
dmbnex
Hi again,
After moving ip sla to global, importing routes to/from vrf/global this worked with both ip sla tracking and route failover from another vrf.
I will probably use some kind of firewall with policy based routing/probe to achieve this as Cisco is way to unpredictable for me as ip sla sometimes works and sometime does not(even i global)
