IP SLA Tracking For Connectivity with Multiple WAN Links
I want to configure Reliable static routing with object tracking. I have a cisco 3825 and 3925 router in which the hsrp will be configured . Now these two routers are connected a remote site via three different WAN connectivity as under
1. MPLS
2. LL-1
3. LL-2
The priority of routing is also the same sequence.
Now if the MPLS goes down the remote site should be connected via LL-1. If both the MPLS and LL-1 goes down the remote site should be connected via LL-2.
The LL-1 is terminated on cisco 3825 and LL-2 is terminated on cisco 3925. MPLS is terminated on both cisco 3825 as well as 3925 router.
Whether multiple tracking  options are available so that i can achieve the same.
Topology diagram is attached.
Fazleabbas
Edison Ortiz
You should look into PfR
http://docwiki.cisco.com/wiki/PfR:Home
Edison
Hi Edison,
Thanx for the reply. Policy feature routing is gr8 feature. Just wanted to know in my setup i am using static routing on 3825, 3925 and 1841 router. I dont want to load balancing of traffic, but if the MPLS connectivity goes down the 1841 should get connected via LL-1 and if LL-2 goes down it should get connected via LL-2 which is connected on 3925.
My concern is i have seen reliable static routing with object tracking with two WAN connectivity, but if  three WAN connection are available how to achieve that
What i was planning to do is create two ip sla's
ip sla monitor 1
type echo protocol ipicmpecho 200.x.x.1                     // Public IP of 1841 router on MPLS connectivity
ip sla monitor schedule 1 start-time now life forever
frequency 3
ip sla monitor 2
type echo protocol ipicmpecho 172.16.2.1                 // Leased Line-1 IP of 1841 router
ip sla monitor schedule 2 start-time now life forever
frequency 3
track 123 rtr 1 reachability
track 124 rtr 2 reachability
ip route 172.16.4.0 255.255.255.0 200.x.x.4 track 123              // to MPLS
ip route 172.16.4.0 255.255.255.0 172.16.2.1 track 124 10        // to LL-1
ip route 172.16.4.0 255.255.255.0 172.16.1.10 20     // traffic will be forwarded to router 3925
Fazleabbas
Your config should work based on the info provided.
