11-24-2021
12:19 AM
- last edited on
11-25-2021
09:30 PM
by
Translator
I configured IP SLA on my test environment. I configured IP SLA on my "EdgeRouter" toward the ISP-1 Router and if ISP-1 router goes down then it shift to other ISP-2 Router. The IP SLA triggerd and all the Users request routed to ISP-2. But the problem is my Edge-Router every 15 to 20 sec change the default router towards my ISP-1 router even thoug my ISP-1 still down and then again change toward ISP-2.
The default route flapping continuously.
My question is it default behavior of IP SLA or any configuration error. Please look my attached topology and Tracking error on Edge Router (Message continuously showing after 15 to 20 sec)
My Edge Router Configuration.
track 1 ip sla 1 reachability
delay down 10 up 10
interface FastEthernet0/0
ip address 192.168.20.2 255.255.255.0
duplex full
interface FastEthernet1/0
ip address 192.168.30.2 255.255.255.0
duplex full
interface FastEthernet2/0
ip address 192.168.10.2 255.255.255.0
duplex full
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.20.1 track 1
ip route 0.0.0.0 0.0.0.0 192.168.30.1 5
ip sla 1
icmp-echo 8.8.8.8
threshold 100
frequency 5
ip sla schedule 1 life forever start-time now
Solved! Go to Solution.
11-24-2021
04:12 AM
- last edited on
11-25-2021
10:11 PM
by
Translator
Hello
Looks like your sla timers are to aggressive.
Try the following and add a local policy route to negate secondary default route from icmp 8.8.8.8:
no ip sla 1
ip sla 1
icmp-echo 8.8.8.8 source-interface fa0/0
timeout 1000
threshold 2000
frequency 15
ip sla schedule 1 start now life forever
track 1 rtr1 reachability
access-list 100 permit icmp host <source ip> host 8.8.8.8 echo
route-map ipsla
match ip address 100
set ip next-hop 192.168.20.1
set interface Null0
ip local policy route-map ipsla
11-24-2021
12:50 AM
- last edited on
11-25-2021
09:35 PM
by
Translator
add either the source-ip or the source-interface to your SLA:
icmp-echo 8.8.8.8 source-ip 192.168.20.2
or
icmp-echo 8.8.8.8 source-interface FastEthernet0/0
11-24-2021 01:18 AM
Thanks for the reply.
After editing the "icmp-echo 8.8.8.8 source-interface FastEthernet0/0" route flapping continuously and getting the same error on Edge-Router.
11-24-2021
03:42 AM
- last edited on
11-25-2021
09:37 PM
by
Translator
Heljlo,
try the entire IP SLA with just the defaults:
ip sla 1
11-24-2021 04:10 AM - edited 11-24-2021 04:11 AM
same result after IP SLA defaults setting.
11-24-2021
04:12 AM
- last edited on
11-25-2021
10:11 PM
by
Translator
Hello
no ip sla 1
ip sla 1
timeout 1000
threshold 2000
frequency 15
route-map ipsla
set interface Null0
11-24-2021
05:14 AM
- last edited on
11-25-2021
09:43 PM
by
Translator
It is working fine. Could you please explain the purpose and function of below highlighted line please.
duplex full
duplex full
duplex full
ip forward-protocol nd
no ip http server
ip sla 1
threshold 2000
frequency 15
access-list 100 permit icmp host 192.168.20.2 host 8.8.8.8 echo
route-map ipsla permit 10
set interface Null0
11-24-2021 05:43 AM - edited 11-24-2021 05:45 AM
Hello
Basically what you are doing is negating the primary wan facing ip from pinging the tracked ip ( 8.8.8.8) via the second backup default route and if it does then drop it which will then allow failover to return to the primary path as/when it again becomes available otherwise failover may not return back to the primary as 8.8.8.8 in this case would be still reachable via the back route.
11-24-2021 05:47 AM
I don't see any NAT and route-maps
! track 1 ip sla 1 reachability delay down 5 up 10 ! ip nat inside source route-map NAT-ISP1 interface FastEthernet0/0 overload ip nat inside source route-map NAT-ISP2 interface FastEthernet1/0 overload ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 192.168.20.2 name ISP1 track 1 ip route 0.0.0.0 0.0.0.0 FastEthernet1/0 192.168.30.2 250 name ISP2 ip route 8.8.4.4 255.255.255.255 FastEthernet0/0 192.168.20.2 name force-ISP1 ip route 8.8.4.4 255.255.255.255 Null0 250 name deny-via-ISP2 ! ! ip access-list extended NAT_LAN 10 permit ip 192.168.0.0 0.0.0.255 any 30 deny ip any any log ! ip sla 1 icmp-echo 8.8.4.4 request-data-size 200 owner SYSADMIN threshold 1000 timeout 3000 frequency 5 history hours-of-statistics-kept 25 history distributions-of-statistics-kept 20 history lives-kept 2 history buckets-kept 60 history filter all ip sla schedule 1 life forever start-time now ip sla enable reaction-alerts ! route-map NAT-ISP1 permit 10 match ip address NAT_LAN match interface FastEthernet0/0 ! route-map NAT-ISP2 permit 10 match ip address NAT_LAN match interface FastEthernet1/0
11-24-2021 06:09 AM - edited 11-24-2021 06:09 AM
Hello @emurray
This post as far as I am aware doesn’t relate to NAT it just pertains to ipsla tracking.
11-25-2021 03:48 PM
following
