IP SLA Tracking Static Route for Back UP
thomasandy32
Hello Dear's,
Pls find the attached,Diagram,
I m configuring IP SLA in the attached secnario,I m pinging the loopback on R2 from R4,the primary tracking route is from R3 and the failover is R5 but the failover from R3 to R5 is maximum 8 sec,Can it be more low, I m referring the Reliable Static Routing Backup Using Object Tracking Document attached.
I having a IOS 12.2.33SXH,
There is also an another document attached PBR and Track command,i m not using those commands in the document,i m referring the reliable static routing backup document,I hope they are doing the same job,If i m not wrong????????????????????? pls confirm.
Attached the configs and diagram.
Once your ip sla monitor is able to ping and recieve reply's from 192.168.10.1, track 123 will wait for 10 seconds before it brings up the static route to 100.100.100.100, which is being tracked.
track 123 rtr 1 reachability
delay down 15 up 10
ip route 100.100.100.100 255.255.255.255 192.168.10.1 track 123
I was suggesting the static default route or a  route-map be placed on R4 since this is the side you sending traffic from. Your running OSPF and you can completely eliminate the sla's. You can have r5 and r3 advertise the r2 loopback and let the dynamic routing do it's thing. You can even manipulate the route atrributes in OSPF to your liking - changing path selection, ad's, injecting static routes etc.... Your failover time would be lower.
15 Replies 15
DialerString_2
Level 3
Level 3
Here's a question why not use a floating static or create a route-map
to verify the next-hop?  OR are you just practicing on the lab?
I have change the configs as per the PBR document attatched  but the failover is too late 1 min 15 sec, Before with Reliable Static Routing Backup it was only 8 sec,
Any additional command that can help much faster failover ??????????. Actually the command  delay {up seconds [down seconds] | [up seconds] down seconds} in PBR document i have not understood this command can it help for faster failover ?? IF SO ,,, then what i shld put ???
I m doing this as a LAB on dynamips secnario before applying to live network.
Awaiting ur replies experts,
Attached are the configs
Thomas,
Once the physical ckt comes up and stays up for 10 seconds the tracking state will go active along with anything your tracking - routes in your case. The same if the interface goes done. Try setting the delays to 0.
track 100 rtr 10
delay down 15 up 10
Question.
Why not use a default route such as ip route 0.0.0.0 0.0.0.0 "next hop" 250 or use route-map to verify availability (if the other device has CDP enabled). It may be easier to troubleshoot depending on what your actually doing.
Route-map test permit 10
Match ip address 10
Set ip next-hop "ip"
set ip next-hop verify-availability
Route-map test permit 20
Hello Experts,
It's the same no effect after applying delays,I applied delay 0 as well as delay down 15 up 10 but no change I have applied a static route with track command and also the route-map with set ip nex-hop verify reacheability,just have a look on the attached configs of the last mail.
I did'nt understood ? ur below words.
Can u explain me why u r advicing to use PBR instead Reliable Static Routing Backup Using Object Tracking ????,
I have attached the configs in my first mail for Reliable Static Routing Backup Using Object Tracking,just review and reply back.
Thanks for ur prompt reply.
R3(config-track)#do sh run
Building configuration...
Current configuration : 1256 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip sla monitor 1
type echo protocol ipIcmpEcho 192.168.10.1
ip sla monitor schedule 1 life forever start-time now
delay down 15 up 10
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0/0
ip address 192.168.10.2 255.255.255.0
ip policy route-map local
duplex auto
speed auto
interface FastEthernet2/0
ip address 192.168.30.2 255.255.255.0
duplex auto
speed auto
router ospf 1
router-id 3.3.3.3
log-adjacency-changes
redistribute static metric 1 subnets
network 3.3.3.3 0.0.0.0 area 0
network 192.168.30.2 0.0.0.0 area 0
ip http server
ip forward-protocol nd
access-list 101 permit icmp any host 192.168.10.1 echo
route-map local permit 10
match ip address 101
set ip next-hop verify-availability 192.168.10.1 10 track 123
route-map local permit 20
control-plane
line con 0
line aux 0
line vty 0 4
login
end
delay down 15 up 10
Hello Experts
I want to apply the configs in real senario in MPLS network, In a Carrier supporting carrier senario
R2 is the customer,(with redundant connection to PE's)
R3 & R5 are the distribution /PE's (the link between the DIST and CORE is MPLS enabled)
R4 is the Core (which is connecting to ISP).
ANSWER:
I will recieve trafic from the ISP for the 100.100.100.100 which is on R2,so i have put the static routes on R3 and R5,
I m running OSPF internal network not with the customer. Only static with the customer.
Question:
How come it is coming up in 7 - 8 sec in Reliable static routing with backup object tracking?????????????????????.
i m fine with Reliable static routing with backup object tracking but can u tell me why u r suggesting me PBR.
Hello Dear's,
Can anybody help me for the above query, I'm also facing the same issue.
Thomas sorry for the delayed reply.
The 7-8 seconds is pretty close but to get an accurate time you need to tear down the link that's being track in this case that would be the f0/0 interface on R3. Once the link is down issue the "show track" command with in 15 seconds and you should see the delay down notification go into effect. You'll noticed the seconds starting to drop. Do the same thing when you bring the link up. Essentially you can log the output to the moniter via term mon.
I thought maybe changing the delay timers would decrease the swithover but apparently it didn't. The threshold and frequency on the sla is low also.
I suggested th PBR because I didn't really know your scenario and what device you are responsible for. However I see what you are doing
and it looks nice,  except for the 7-8 second delay on failover.  It seems like it would be hard not to get any delay in this setup, even more so because your not performing dynamic routing between the customer and the PE's.
Hello Dear's,
SO THE CONCLUSION IS Reliable Static Routing Backup Using Object Tracking IS THE PERFECT SOLUTION FOR THE CURRENT SCENARIO.
THANKS
Hey,
Being that your not running a routing protocol between the PE and the Customer,  you have no way of proving the availability of 100.100.100.100 from R4 w/ out the use of static routes -which are being injected into OSPF.  I believe this is a good efective solution and there's no perfect network anywhere you go!
However if there's a better way of doing it I would love to know.
That's True Dear,
No where in the world u will get fully failover within a seconds,
Thanks for ur replies,hope to see u soon in the next thread,Keep it up,be with ur helping nature it will lead to success,
Cheers,
Thanks for the rating Sandy and see ya next time, Packet Head!
I try with this configuration but not work:
Spoiler
track 10 ip sla 10 reachability
ip sla 10
 icmp-echo x.170.119.181 source-ip X.170.119.100
ip sla schedule 10 life forever start-time now
ip route 0.0.0.0 0.0.0.0 x.170.119.181 name D_T_P track 10
I still see route from the OSPF, how should I do?
which route do you still see ? Post the full running configuration of your router.
For the IP SLA to work, you need a static host route pointing to the interface (or the next hop address of the interface) that is being tracked:
ip route x.170.119.181 255.255.255.255 ip_address-of_next-hop or outgoing_interface
