Showing results forĀ
Search instead forĀ
Did you mean:Ā
ip sla will not inject route back to the original default gateway
feisalb
Hello All
I am trying to run ip sla on a cisco 1921 router on ver 15.4(3)M1.
This is the config and the routing table. Once I configure "ip route 10.251.120.141 255.255.255.255 10.108.47.2 track 1"
it seems that the ip sla starts to kicking and makes the dialer 1 the route for this host (10.251.120.141) and this never comes points back
to the original gateway 10.108.47.2
Running config is:
track 1 ip sla 1 reachability
ip route 0.0.0.0 0.0.0.0 10.108.47.2
ip route 10.251.113.1 255.255.255.255 10.108.47.2
ip route 10.251.120.141 255.255.255.255 Dialer1 250
ip sla 1
 icmp-echo 10.251.120.141 source-ip 10.108.42.1
 timeout 10000
 frequency 15
ip sla schedule 1 life forever start-time now
S*    0.0.0.0/0 is directly connected
      10.0.0.0/8 is variably subnetted, 14 subnets, 3 masks
C        10.32.240.0/28 is directly connected, GigabitEthernet0/0.301
L        10.32.240.1/32 is directly connected, GigabitEthernet0/0.301
C        10.108.42.0/24 is directly connected, GigabitEthernet0/0.318
L        10.108.42.1/32 is directly connected, GigabitEthernet0/0.318
C        10.108.44.0/24 is directly connected, GigabitEthernet0/0.319
L        10.108.44.1/32 is directly connected, GigabitEthernet0/0.319
C        10.108.45.0/24 is directly connected, GigabitEthernet0/0.320
L        10.108.45.1/32 is directly connected, GigabitEthernet0/0.320
C        10.108.46.0/24 is directly connected, GigabitEthernet0/0.321
L        10.108.46.1/32 is directly connected, GigabitEthernet0/0.321
C        10.108.47.0/28 is directly connected, GigabitEthernet0/0.330
L        10.108.47.1/32 is directly connected, GigabitEthernet0/0.330
S        10.251.113.1/32 [1/0] via 10.108.47.2
S        10.251.120.141/32 is directly connected, Dialer1 <------
      150.101.0.0/32 is subnetted, 1 subnets
C        150.101.32.44 is directly connected, Dialer1
      203.206.184.0/32 is subnetted, 1 subnets
C        203.206.184.247 is directly connected, Dialer1
Any ideas on how to fix this.
Thank
Feisal
Kelvin Willacey
Level 4
Level 4
Is the tracked object up? Do a 'show track'
Fixed by adding a permanent static route to the icmp echo target.
Thanks for your response
Feisal
