IP SLA
Salman-Abbasi
Hi Team ,
I have one requirement that whenever PC1 and 8.8.8.8 reachability goes down due to any reason and consider 8.8.8.8 is CLOUD IP then R2 interface f2/0 should also be down like state or protocol of interface can we achieve this through IPSLA or any other way.
Salman
2 Accepted Solutions
Hello
You dont mention what IOS your are using and on what platform, however its possibile a simple EEM can be applied
Simple EEM
ip sla 10
icmp-echo 8.8.8.8 source-ip x.x.x.x
timeout 200
frequency 5
ip sla schedule 10 life forever start-time now
track 1 rtr 10 reachability
event manager applet FA02-DOWN
event track 1 state down
action 5.0 cli command "enable"
action 5.1 cli command "conf t"
action 5.2 cli command "interface fa0/2"
action 5.3 cli command "shut"
action 5.4 cli command "end"
event manager applet FA0/2-UP
event track 1 state up
action 5.5 cli command "enable"
action 5.6 cli command "conf t"
action 5.7 cli command "interface fa0/2"
action 5.8 cli command "no shut"
action 5.9 cli command "end
Kind Regards
Paul
Hi MHM Cisco World,
Everything is working fine after configured IP SLA with EEM template.
35 Replies 35
Use EEM to detect IP SLA status and action down interface
MHM
Hi MHM Cisco World
Could you please share the EEM configuration.
You want interface to be down to remove default route?
MHM
My requirement is when 8.8.8.8 not reachable from R2 then interface f2/0 should be down.
And how yoh make it UP again?
This my concern
MHM
I can Manually bring up the interface.
Kindly ignore last reply
When 8.8.8.8 will be reachable from R2 then f2/0 auto up the interface.
Sorry that cannot be done
Check my below reply
MHM
Example
ip sla 1
icmp-echo 8.8.8.8 source-interface x/x
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
event manager applet IPSLA
action 1.0 cli “enable”
action 2.0 cli “conf t”
action 3.0 cli “int x/x”
action 4.0 cli “shut”
action 5.0 cli “end”
Hello
Simple EEM
ip sla 10
timeout 200
frequency 5
Kind Regards
Paul
Thank you so much it is working.
@paul driver @Salman-Abbasi
It never work
Because ip sla use IP to be UP and you admin down it.
I know what I am talking about
If IP Sla is up and the port is admin down then IP sla use different path and that so so wrong
It easy logic
MHM
Hello
It never work
The source interface of the ipsla isnt the interface the OP wants to shut down when tracking fails so yes the above cfg WILL work.
Kind Regards
Paul
If he use different ip sla source interface then what logic of eem and IP sla???
Friends take a min think about issue
MHM
