02-03-2012 08:52 AM - edited 03-04-2019 03:07 PM
I am trying to configure a Cisco 3945. When enter the command:
ip subnet-zero
and the do a
sh run
The running config does not show that subnet-zero is active. I even tried
sh run | inc subnet
and still see nothing. Why is the command not taking? I just want to configure the router with 2 IP addresses and a gateway of last resort.
Example:
Gige 0/0
ip address 192.168.1.1 255.255.255.252
duplex full
speed 1000
Gige 0/1
ip address 10.1.1.1 255.255.255.224
duplex auto
speed auto
For some reason when I configure Gige 0/1 it tells me that /27 is not allowed even though I set
ip classless
Can anyone please assist? Thanks!
Solved! Go to Solution.
02-03-2012 08:56 AM
ip subnet-zero in enabled by default.
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_ip.html#wp1013596
Can you provide the exact error during the configuration along with the entire config?
02-03-2012 08:56 AM
02-03-2012 10:11 AM
oh man.. rookie mistake.. I was accidentally using the subnet IP for the gi 0/1
Oops! guess thats what happens when you make your configuration checklist at 3am
Thanks for the help!
