QoS - packets arriving on the interface
kunal-united
In have a cisco 2801 router, fast 0/0 - internal network and fast 0/1 - internet
I have packets coming into fast 0/0 with dscp values ef, cs3, cs5, etc ... going the the internet thru fast 0/1.
I only have basic configuration on fast 0/1 - no service-policy, no class-map, configured
Scenario: packets with dscp values arriving in fast 0/0 will exit fast 0/1 to the internet.
Question: Will these packets will be tagged the same dscp values when they exit to the internet?
Is this true or do I have make some configuration changes at my end to have this scenario configured.
Please provide reference. All are fastethernet interfaces.
class-map match-any VoIP-Signalling
match ip dscp af31
match ip dscp cs3
match ip dscp cs5
match ip dscp ef
policy-map VOIP-QoS
class VoIP-Audio
priority 2500
class VoIP-Sig
bandwidth 100
class class-default
fair-queue
Edison Ortiz
The tags will be preserved as they traverse the router unless you create a policy that alters it.
match ip dscp af31
match ip dscp cs3
match ip dscp cs5
match ip dscp ef
policy-map VOIP-QoS
class VoIP-Audio
priority 2500
class VoIP-Sig
bandwidth 100
class class-default
fair-queue
Your policy-map is not configured properly.
class VoIP-Audio != VoIP
class VoIP-Sig != VoIP Signalling
You have to make sure whatever name used in the class-map matches the class used under the policy-map.
Edison
Edison Ortiz
match ip dscp af31
match ip dscp cs3
match ip dscp cs5
match ip dscp ef
policy-map VOIP-QoS
class VoIP-Audio
priority 2500
class VoIP-Sig
bandwidth 100
class class-default
fair-queue
Edison
