12-26-2014 06:21 AM - edited 03-05-2019 12:27 AM
Hello Guys,
Happy christmas and new year to you all.
I am trying to fix this issue since a month with no results. I am trying to move the internet line which is basically a ethernet handoff. I informed my site engineer to move the cable from yamaha router to cisco router on gigabit interface port during maintanence window. When he unplugs the cable from yamaha router and plugs into cisco router the ping to ISP is not working. Basically I enter default route pointing to ISP address. But when he reverts back to yamaha router pings works and hence the internet works without any issues. I found out through forum these might be arp which doesn't allow you to ping the ISP. ISP has to change the arp table or its gets updated dynamically. The cable was plugged for atmost 2 days during weekends. But the arp table didn't got updated and ping dies when pinging to ISP router. Response from ISP was we have to nothing from our end. Now it seems like we have no where to go.
Little help about how to approach the problem will be highly appreciated.
Thanks in advance
12-26-2014 06:30 AM
Could you please post a show ip int brief, a show interface <interface-id> of the interface connected to the ISP, and a show ip arp and ? Optinally the show running would also help.
KR
12-26-2014 06:45 AM
Show int G0/2
GigabitEthernet0/2 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 6c20.563b.1052 (bia 6c20.563b.1052)
Description: To Internet - Ethernet Handoff
Internet address is xxx.xxx.173.250/30
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
191598 packets input, 19767052 bytes, 0 no buffer
Received 128046 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
81231 packets output, 11226587 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
3 lost carrier, 0 no carrier, 0 pause output
show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.30.11 0 Incomplete ARPA
Internet 192.168.30.13 77 0016.355d.d75a ARPA GigabitEthernet0/0
Internet 192.168.30.22 242 0420.9a41.3399 ARPA GigabitEthernet0/0
Internet 192.168.30.23 204 cc7e.e75f.921d ARPA GigabitEthernet0/0
Internet 192.168.30.24 201 100b.a9dd.9a28 ARPA GigabitEthernet0/0
Internet 192.168.30.28 0 Incomplete ARPA
Internet 192.168.30.32 229 f437.b7b5.749b ARPA GigabitEthernet0/0
Internet 192.168.30.33 243 6480.9969.09f8 ARPA GigabitEthernet0/0
Internet 192.168.30.50 265 f437.b7b7.168f ARPA GigabitEthernet0/0
Internet 192.168.30.100 - 6c20.563b.1050 ARPA GigabitEthernet0/0
Internet 192.168.30.101 77 0017.0e14.5340 ARPA GigabitEthernet0/0
Internet 192.168.30.111 3 0016.355b.f83a ARPA GigabitEthernet0/0
Internet 192.168.30.112 1 0014.c25f.6f03 ARPA GigabitEthernet0/0
Internet 192.168.30.114 0 000f.eaf2.340a ARPA GigabitEthernet0/0
Internet 192.168.30.115 0 0011.0939.92b0 ARPA GigabitEthernet0/0
Internet 192.168.30.120 76 0024.a559.414e ARPA GigabitEthernet0/0
Internet 192.168.30.200 67 0800.37d6.6fa6 ARPA GigabitEthernet0/0
Internet 192.168.30.202 65 0800.37d6.752b ARPA GigabitEthernet0/0
Internet 192.168.30.204 1 001e.8f37.b62c ARPA GigabitEthernet0/0
Internet 192.168.30.206 53 0800.37d6.3ef6 ARPA GigabitEthernet0/0
Internet 192.168.30.253 16 00a0.de82.c063 ARPA GigabitEthernet0/0
Internet 192.168.250.37 - 6c20.563b.1060 ARPA SM1/0
Internet 192.168.250.38 0 6c20.561c.3361 ARPA SM1/0
Internet 192.168.254.45 0 0019.e299.5ff1 ARPA GigabitEthernet0/1
Internet 192.168.254.46 - 6c20.563b.1051 ARPA GigabitEthernet0/1
Internet xxx.xxx.173.249 0 0012.4387.6c7f ARPA GigabitEthernet0/2
Internet xxx.xxx.173.250 - 6c20.563b.1052 ARPA GigabitEthernet0/2
show ip int brief
GigabitEthernet0/0 192.168.30.100 YES NVRAM up up
GigabitEthernet0/1 192.168.254.46 YES NVRAM up up
GigabitEthernet0/2 xxx.xxx.173.250 YES manual up up
SM1/0 192.168.250.37 YES NVRAM up up
show run | in ip route
ip route 0.0.0.0 0.0.0.0 xxx.xxx.173.249
ip route 0.0.0.0 0.0.0.0 192.168.30.253 255 (this goes to yamaha router through LAN for internet)
ip route 192.168.31.0 255.255.255.0 192.168.30.253(this goes to warehouse another yamaha router)
interface GigabitEthernet0/2
description To Internet - Ethernet Handoff
ip address xxx.xxx.173.250 255.255.255.252
ip access-group 110 in
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map JAPWARE
end
Thanks in advance.
12-26-2014 06:45 AM
Also I do notice in the show int g0/2 output
3 lost carrier
The lost carrier counter increases each time a carrier sense loss occurs. This happens when the hardware is transmitting a frame onto the wire and does not see its own carrier wave on the Ethernet.
The absence of the carrier signal increments the no carrier counter.
What could be the issue?
Thanks in advance...
12-26-2014 06:56 AM
Are you fixing the speed/duplex under the interface g0/2 ? To what parameters has your priver fixed his port?
12-26-2014 06:59 AM
Thanks for your reply
I didn't make any changes regarding the speed and duplex. Should i need to talk to provider for these parameters to be in place.
12-26-2014 07:06 AM
The provider should let you know how he configures his port.
Otherwise if you still can reach your yahama router, you can check what are the configured speed/duplexing settings and mimic that on your 2911 g0/2 port.
What's the purpose of your ip access-group 110 in actually?
12-26-2014 07:12 AM
This is what it displays in yamaha router
show status lan2 (seems like it is set to Auto Negotiation)
LAN2
Description:
IP Address: xxx.xxx.173.250/30
Ethernet Address: 00:a0:de:82:c0:64
Operation mode setting: Auto Negotiation (Link Down)
Maximum Transmission Unit(MTU): 1500 octets
Promiscuous mode: OFF
Transmitted: 79591508 packets (28280217956 octets)
IPv4(all/fastpath): 79542797 packets / 66636127 packet
IPv6(all/fastpath): 4 packets / 0 packet
Received: 103780974 packets (102051541671 octets)
IPv4: 99533015 packets
IPv6: 0 packet
Access-list 110 (Internet outside interface best practices)
access-list 110 remark FROM_OUTSIDE_INTERNET
access-list 110 permit gre host x.xx.106.21 host xxx.xxx.173.250 log
access-list 110 permit gre host x.xx.106.20 host xxx.xxx.173.250 log
access-list 110 permit esp host x.xx.106.21 host xxx.xxx.173.250 log
access-list 110 permit esp host x.xx.106.20 host xxx.xxx.173.250 log
access-list 110 permit udp host x.xx.106.21 host xxx.xxx.173.250 eq isakmp log
access-list 110 permit udp host x.xx.106.20 host xxx.xxx.173.250 eq isakmp log
access-list 110 remark VPN SITE-TO-SITE JAPAN - WAREHOUSE
access-list 110 permit udp any host xxx.xx.8.178 eq isakmp
access-list 110 permit udp any host xxx.xx.8.178 eq non500-isakmp
access-list 110 permit udp any host xxx.xx.8.178 eq 10000
access-list 110 permit esp any host xxx.xx.8.178
access-list 110 permit udp host xxx.xx.8.178 eq isakmp any
access-list 110 permit udp host xxx.xx.8.178 eq non500-isakmp any
access-list 110 permit udp host xxx.xx.8.178 eq 10000 any
access-list 110 permit esp host xxx.xx.8.178 any
access-list 110 deny ip 192.168.30.0 0.0.0.255 any log
access-list 110 deny ip 192.168.31.0 0.0.0.255 any log
access-list 110 deny ip 10.0.0.0 0.255.255.255 any log
access-list 110 deny ip 172.16.0.0 0.15.255.255 any log
access-list 110 deny ip 192.168.0.0 0.0.255.255 any log
access-list 110 deny ip 127.0.0.0 0.255.255.255 any log
access-list 110 deny ip host 255.255.255.255 any log
access-list 110 deny ip host 0.0.0.0 any log
access-list 110 deny ip any any log
Thanks for your reply......
12-26-2014 07:28 AM
From you ACL output, ping reply towards xxx.xxx.173.250 address is not allowed...
there is no permit statement allowing ping reply back...
12-26-2014 07:38 AM
Thanks for your reply. Its working now. The access-list was the culprit. Thank you very much.
12-26-2014 07:40 AM
No worries. I'm glad it's working for you !
And have a happy new year !
12-26-2014 07:51 AM
For making internet and site to site vpn to yamaha router work what need to opened could you please suggest.
When I apply that access-group 110 in on the interface - internet and pings stop working.
Atleast my nat statements are working and hence internet working when i take off my access-group 110 in.
Sorry for being layman.
Appreciate for your help.
Please refer to the access-list 110 for more info.
12-26-2014 06:51 AM
When performing your ping test, is it from the router or from a device behind the router ?
What give a ping from the router towards ISP xxx.xxx.173.249 address? Is all ..... or another message?
12-26-2014 06:55 AM
Its from cisco router 2911 and i am getting ..... Request time out.
