IPsec suuport
mohamed_afarrag
Hello
We have ASR 1006X With software image 17.9
How to verify that it will support IPSec configuration? Is it related the rouer image or the license?
Please note that, currently we didn't have access to it to verify using command line
5 Replies 5
you need to have access not only to check command to do
show version
show license
MHM
Hello @mohamed_afarrag ,
The Cisco ASR 1000 Series Router IPsec application requires an RTU license FLASR1-IPSEC-RTU=, which allows you to enable IPsec Triple Digital Encryption Standard (3DES) and Advanced Encryption Standard (AES), Dynamic Multipoint VPN (DMVPN), and Easy VPN.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
Hello
Version 17.06.05
License Level: adventerprise
mohamed_afarrag
Version 17.06.05
Can you share the output of show license usage command?
Regards, LG
