IPSEC tunnel and GRE
ajike ola
I need your help understanding this configuration:
I was trying out GRE over IPSEC in my home lab, using the following configuration:
R1==>R3==>R2
My GRE and IPSEC originate at R1 and terminate on R2, and I verified that the tunnel is up and running on both R1 and R2. I also verified the packets are being encapsulated and encrypted, using "show crypto ipsec sa".
However, when I connected a PC to R3, I was able to ping both R1 and R2.
I didn't think I should be able to do this, given this is supposed to be a secured tunnel.
Someone please help me understand
22 Replies 22
Thank you very much. This really helped me see what I was missing in my configuration.I added routing protocol (OSPF), and was able to ping network on the other side of R1 and R2, however I do not see the pings packet counts. I modified the access-list to include those networks, but that didn't help.
Thanks.
If you are able to ping and the packets do not show as encrypted, then we have a problem with the ACL.
Can you post your config just like I did? It will definitely help.
First, I am sorry for not being able to get this to work, and the trouble you have gone through to help me. Thank you.
Since you have basically spoon-fed me up to this point, I wanted to give it a shot, and I have for the last couple of days, and still don't know what I am doing wrong. I have incorporated your config into mine, and back and forth, nothing seems to work. If I ping from the Internet router to either R2 or R3 interfaces, I could see the packets go through the tunnels, however if I ping from the internet router to either Server 2 or Server 3, I get failure. Also, if I ping from the NMS-PC to either server 2 or server 3 (with OSPF configured), I was successful, however the packets don't go through the tunnels.
                                        NMS-PC
                                             V
Server 2 ==> R2 ==> Internet Router ==> R3 ==> Server 3
The objective is as follows:
  • All packets originating from Internet Router should go through the  tunnel to server2 and server3
  • All packets from NMS-PC to go through the tunnel; that is NMS-PC to be able to see server2 and server3 through the tunnels; I tried verifying this by pinging, but I couldn't see any packet counts in the tunnels.
  • And, all packets from server2 and server3 to go through the tunnel to NMS-PC
Here is my config:
sh run
Building configuration...
Current configuration : 2038 bytes
version 12.4
hostname Internet
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip cef
crypto isakmp policy 1
encr aes
authentication pre-share
crypto isakmp key adupa address 172.16.2.2
crypto isakmp key adupa address 172.16.3.2
crypto ipsec transform-set transet esp-aes 256 esp-sha-hmac
crypto map gre_ipsec 10 ipsec-isakmp
set peer 172.16.2.2
set transform-set transet
match address gre-ipsec2
crypto map gre_ipsec 20 ipsec-isakmp
set peer 172.16.3.2
match address gre-ipsec3
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel1
ip address 172.168.16.1 255.255.255.0
tunnel source 172.16.2.1
tunnel destination 172.16.2.2
interface Tunnel2
ip address 172.168.17.1 255.255.255.0
tunnel source 172.16.3.1
tunnel destination 172.16.3.2
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 100
ip address 172.16.2.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 200
ip address 172.16.3.1 255.255.255.0
interface FastEthernet0/1
ip address 172.168.2.254 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 2.2.2.2 255.255.255.255 Tunnel1
ip route 3.3.3.3 255.255.255.255 Tunnel2
ip route 172.168.3.0 255.255.255.0 Tunnel1
ip route 172.168.4.0 255.255.255.0 Tunnel2
no ip http server
no ip http secure-server
ip access-list extended gre-ipsec2
permit gre host 172.16.2.1 host 172.16.2.2
permit gre host 192.168.2.253 host 172.16.2.2
permit gre host 192.168.2.254 host 172.16.2.2
ip access-list extended gre-ipsec3
permit gre host 172.16.3.1 host 172.16.3.2
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
=========================================R2 Config================================
sh run
Current configuration : 1223 bytes
version 12.3
hostname R2
boot-start-marker
boot-end-marker
ip cef
ip audit po max-events 100
encr aes
crypto isakmp key adupa address 172.16.2.1
set peer 172.16.2.1
match address gre-ipsec1
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel1
ip address 172.168.16.2 255.255.255.0
tunnel source 172.16.2.2
tunnel destination 172.16.2.1
interface f0/0
ip address 172.16.2.2 255.255.255.0
full-duplex
interface f0/1
ip address 172.168.3.154 255.255.255.0
full-duplex
no keepalive
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Tunnel1
ip access-list extended gre-ipsec1
permit gre host 172.16.2.2 host 172.16.2.1
permit gre host 172.16.3.153 host 172.16.2.1
permit gre host 172.16.3.154 host 172.16.2.1
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R2#
=====================================R3 Config===============================
sh run
Current configuration : 1336 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
encr aes
crypto isakmp key adupa address 172.16.3.1
set peer 172.16.3.1
interface Loopback0
ip address 3.3.3.3 255.255.255.0
interface Tunnel1
ip address 172.168.17.2 255.255.255.0
tunnel source 172.16.3.2
tunnel destination 172.16.3.1
ip address 172.16.3.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
ip address 172.168.4.154 255.255.255.0
duplex auto
speed auto
ip http server
permit gre host 172.16.3.2 host 172.16.3.1
permit gre host 172.168.4.153 host 172.16.3.1
permit gre host 172.168.4.154 host 172.16.3.1
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R3#
Let's cleanup your ACL:
You should be able to ping 1.1.1.1 from 3.3.3.3 by using the following command:
ping 1.1.1.1 source lo0
traffic should show encrypted and ping should be successful.
I didn't see the OSPF configuration on your post but all you need to do is enable OSPF in the tunnels and LAN interfaces, for instance:
router ospf 1
network 172.168.16.1 0.0.0.0 area 0
network 172.168.17.1 0.0.0.0 area 0
network 1.1.1.1 0.0.0.0 area 0
network 172.168.2.254 0.0.0.0 area 0
default-information originate always
router ospf 1
network 172.168.16.2 0.0.0.0 area 0
network 172.168.3.154 0.0.0.0 area 0
network 2.2.2.2 0.0.0.0 area 0
router ospf 1
network 172.168.17.2 0.0.0.0 area 0
network 3.3.3.3 0.0.0.0 area 0
network 172.168.4.154 0.0.0.0 area 0
Sorry, I did configure OSPF, but must have taken them out in frustration. Anyway,  I think I had too many things going wrong in the config anyway.
Finally, with the clean up above, everything works just fine.
I can't thank you enough
Excellent!
BTW, you will encounter fragmentation issues with GRE which you need resolve with PMTUD.
Please refer to this link for more info:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
Edison
Thanks again, I will keep that in mind.
