07-01-2019 04:00 AM
I am trying to bring up a secondary tunnel via a secondary (3G Cellular data) gateway between our company and a 3rd party vendor. Our primary tunnel is down due to provider's network issue and would take time to re-establish. However, I am unable to bring up the tunnel, not even phase 1. Our device is Cisco C819HG-4G-G-K9 and vendor is using StrongSwan.
Our configuration:
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key ***** address 1.1.1.1
crypto ipsec transform-set TS esp-aes 256 esp-sha-hmac
mode tunnel
crypto dynamic-map MAP 10
set transform-set TS
match address TUNNEL
set peer 1.1.1.1
crypto map MAP 10 ipsec-isakmp dynamic MAP
interface Tunnel8
bandwidth 2048
ip address 192.168.9.253 255.255.255.252
ip flow ingress
ip flow egress
ip tcp adjust-mss 1360
tunnel source Cellular0
tunnel destination 1.1.1.1
crypto map MAP
interface Cellular0
ip address negotiated
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
Extended IP access list TUNNEL
10 permit ip 192.168.8.0 0.0.0.255 10.58.1.0 0.0.0.255 (30 matches)
Vendor Configuration:
conn grem-umts
left=1.1.1.1
leftsubnet=10.58.1.0/24
leftsourceip=192.168.9.254
leftnexthop=%defaultroute
right=0.0.0.0
rightsubnet=192.168.8.0/24
rightnexthop=192.168.9.253
authby=secret
ike=aes256-sha1-modp1024
esp=aes256-sha1
keyexchange=ike
auth=esp
keylife=24h
ikelifetime=24h
pfs=no
forceencaps=yes
auto=add
Running on
DISTRIB_ID="OpenWrt"
DISTRIB_RELEASE="Bleeding Edge"
DISTRIB_REVISION="r33603"
DISTRIB_CODENAME="attitude_adjustment"
DISTRIB_TARGET="x86/64bitkvm"
DISTRIB_DESCRIPTION="OpenWrt Attitude Adjustment r33603"
Appreciate any help/inputs.
3GDEVICE#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
IPv6 Crypto ISAKMP SA
Nothing from the debug output as well.
3GDEVICE#debug crypto isakmp
Crypto ISAKMP debugging is on
3GDEVICE#debug crypto ipsec
Crypto IPSEC debugging is on
07-01-2019 04:26 AM
post the full running configuration. Is your Cellular up ?
07-01-2019 06:38 AM
07-01-2019 06:40 AM - edited 07-01-2019 06:41 AM
Am able to ping the peer IP address as well from this device.
07-01-2019 11:47 AM
Phase 1 does not even kick in when I try to initiate interesting traffic by pinging to vendor LAN's server from our device Tunnel 8 interface. The ping also fails.
Please help here. Been stuck with this for a couple of days now.
07-01-2019 12:18 PM
Hello
Before you apply IPSec does the gre tumnel establish?
Are you able to reach each tumnel destination up from the other tunnel source ip without any IPSec applied.
07-02-2019 12:17 AM
No, am not able to reach the other end of the tunnel - 192.168.9.254.
interface Tunnel8
bandwidth 2048
ip flow ingress
ip flow egress
crypto map MAP
ip mtu 1400 >>>>>>>> ADDED THIS CONFIG AS WELL TO THE TUNNEL INTERFACE
3GDEVICE#sh int tun8
Tunnel8 is up, line protocol is up
Hardware is Tunnel
Description: BACKUP_TUNNEL_TO_SAGE
Internet address is 192.168.9.253/30
MTU 17916 bytes, BW 2048 Kbit/sec, DLY 50000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 10.2.19.54 (Cellular0), destination 1.1.1.1
Tunnel Subblocks:
src-track:
Tunnel8 source tracking subblock associated with Cellular0
Set of tunnels with source Cellular0, 2 members (includes iterators), on interface <OK>
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255, Fast tunneling enabled
Tunnel transport MTU 1476 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input 00:04:11, output 00:01:28, output hang never
Last clearing of "show interface" counters 1w3d
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
40 packets output, 4960 bytes, 0 underruns
0 unknown protocol drops
07-02-2019 12:34 AM
3GDEVICE#ping 192.168.9.254 source 192.168.9.253
Sending 5, 100-byte ICMP Echos to 192.168.9.254, timeout is 2 seconds:
Packet sent with a source address of 192.168.9.253
Success rate is 0 percent (0/5)
07-02-2019 12:52 AM
can you ping 1.1.1.1 ? Best to post the full configs of both routers, with partial configs it remains guesswork...
07-02-2019 01:35 AM
Hello
May i suggest to remove the crypto map from the tunnel and test connectivity again, without basic connectivity this isnt going work even if you apply ipsec.
07-01-2019 02:31 PM
the configuration you have posted is partial (the inside source access list NAT is not there, and there are no inside NAT and LAN interfaces). Can you post the full running configuration ?
Either way, the crypto map and the dynamic map have the exact same name, I am not sure what the effect of that is, try and change the name to what I marked in bold.
Also try and apply the crypto map to the physical inside interface instead of the tunnel...
WLAN_AP_SM: Config command is not supported
Current configuration : 6151 bytes
! Last configuration change
version 15.3
service password-encryption
hostname 3GDEVICE
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authentication login default local group radius
aaa authorization exec default group radius if-authenticated
aaa authorization network default group radius if-authenticated
aaa accounting exec default start-stop group radius
aaa session-id common
ip flow-cache timeout active 1
ip domain name abc.xyz
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C819HG-4G-G-K9 sn ***
username *** privilege 15 secret 5 ******
controller Cellular 0
ip ssh version 2
encr aes 256
group 2
encr 3des
group 2
crypto isakmp key ***** address 2.2.2.2 >>>>>>>>>>> WORKING TUNNEL KEY
crypto isakmp key ***** address 1.1.1.1 >>>>>>>>>>> NON WORKING TUNNEL KEY
crypto ipsec transform-set ABC esp-3des esp-sha-hmac
mode tunnel
mode tunnel
crypto ipsec nat-transparency spi-matching
crypto ipsec profile DynVPNprofile
set transform-set office
crypto dynamic-map IPSEC-MAP 10
set peer 1.1.1.1
crypto map MAP 10 ipsec-isakmp dynamic IPSEC-MAP
interface Tunnel8 >>>>>>>>>>>>> NON WORKING TUNNEL
bandwidth 2048
ip flow ingress
ip flow egress
crypto map MAP
interface Tunnel100 >>>>>>>>>>>> WORKING TUNNEL
bandwidth 1024
ip address 10.0.0.61 255.255.255.0
ip mtu 1400
ip flow ingress
ip flow egress
ip nhrp authentication *****
ip nhrp map 10.0.0.1 2.2.2.2
ip nhrp map multicast 2.2.2.2
ip nhrp network-id 16
ip nhrp holdtime 300
ip nhrp nhs 10.0.0.1
ip nhrp registration timeout 10
ip summary-address eigrp 64900 X.X.X.X X.X.X.X
tunnel destination 2.2.2.2
tunnel key 16
tunnel protection ipsec profile DynVPNprofile
interface Cellular0
ip flow ingress
ip flow egress
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface FastEthernet0
description LAN
switchport access vlan 2
no ip address
interface FastEthernet1
description LAN
no ip address
interface FastEthernet2
description LAN
no ip address
interface FastEthernet3
description LAN
no ip address
interface GigabitEthernet0
description LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0.8
XXXX
interface GigabitEthernet0.74
XXXX
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
ip nat inside source list NAT interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip route 10.2.1.0 255.255.255.0 Tunnel8
ip access-list extended TUNNEL
permit ip 192.168.8.0 0.0.0.255 10.2.1.0 0.0.0.255
07-02-2019 01:36 AM
Hello
