Cisco 2851 router to Cable modem help needed
Michael Durham
Level 4
Level 4
I just switched from a ISP that provided a router for Internet connection to one that uses a modem and now no networks can get out to the Internet.  I tested the modem directly to a PC and it works perfect.
ISP Modem --> 2851  --> Switch ---> PC's etc
The modem is connected to port fa0/3/0
There are both static IP address on my servers and print servers, some workstations too.  Other workstations and wifi get dhcp addresses.
The IPS is NOT a static IP address.  Can someone please tell me what I am missing/doing wrong?
Thank You.
My router configuration:
ip source-route
ip cef
ip dhcp smart-relay
ip dhcp relay information option
ip dhcp excluded-address 192.168.69.1 192.168.69.240
ip dhcp excluded-address 10.110.0.1 10.110.0.20
ip dhcp excluded-address 192.168.125.1 192.168.125.9
ip dhcp excluded-address 192.168.200.1 192.168.200.99
ip dhcp excluded-address 192.168.200.102 192.168.200.109
ip dhcp excluded-address 192.168.200.112 192.168.200.219
ip dhcp excluded-address 192.168.26.1 192.168.26.99
ip dhcp pool Wiireless
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
domain-name thedurhamcorporation.com
dns-server 8.8.8.8
option 150 ip 10.110.0.1
lease 0 12
ip dhcp pool Users
network 192.168.69.0 255.255.255.0
default-router 192.168.69.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Voice
network 10.110.0.0 255.255.255.0
default-router 10.110.0.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Reserved69
host 192.168.69.101 255.255.255.0
hardware-address 0800.091a.8987
dns-server 8.8.8.8
ip dhcp pool Hopper_Durham
host 192.168.200.100 255.255.255.0
client-identifier 000d.c5d1.dfb1
dns-server 8.8.8.8
ip dhcp pool Joey_Durham
host 192.168.200.101 255.255.255.0
client-identifier 000d.c5e1.62fb
dns-server 8.8.8.8
ip dhcp pool Hopper_Sommers
host 192.168.200.110 255.255.255.0
dns-server 8.8.8.8
ip dhcp pool Joey_Sommers
host 192.168.200.111 255.255.255.0
dns-server 8.8.8.8
ip dhcp pool TempVMware
network 192.168.70.0 255.255.255.0
default-router 192.168.70.1
dns-server 8.8.8.8
ip dhcp pool CUCM_Voice
network 192.168.27.0 255.255.255.0
default-router 192.168.27.1
dns-server 8.8.8.8
option 150 ip 192.168.26.10
ip domain lookup source-interface GigabitEthernet0/0
ip domain name thecorporation.com
ip name-server 4.2.2.2
ip name-server 8.8.8.8
no ipv6 cef
password encryption aes
voice-card 0
license udi pid CISCO2851 sn FTX15
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
username mdurham privilege 15 password 7 052E021A343
redundancy
track 10 ip sla 1 reachability
delay down 1 up 1
track 20 ip sla 2 reachability
delay down 1 up 1
gw-accounting syslog
description "VMWare Server"
no ip address
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0.26
encapsulation dot1Q 26
ip address 192.168.26.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
ip nat inside
interface Service-Engine0/1
description "CUE-AIM Voicemail & Auto Attendant Module"
ip unnumbered GigabitEthernet0/1.110
ip nat inside
service-module ip address 10.110.0.2 255.255.255.0
service-module ip default-gateway 10.110.0.1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2
ip address 192.168.0.253 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.27
encapsulation dot1Q 27
ip address 192.168.27.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.69
description "Data Network"
encapsulation dot1Q 69 native
ip address 192.168.69.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.110
description "Voice Network"
encapsulation dot1Q 110
ip address 10.110.0.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.125
description "TV & Media Network"
encapsulation dot1Q 125
ip address 192.168.125.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.200
description "Wireless - Guest User Network"
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip access-group 100 in
ip nat inside
interface FastEthernet0/3/0
description Internet Connection to TP Link & Verizon G4
ip address dhcp client-id FastEthernet0/3/0
ip nat outside
duplex auto
speed auto
interface GigabitEthernet1/0
ip address 192.168.70.1 255.255.255.0
ip nat inside
router eigrp 1577
network 10.110.0.0 0.0.0.255
network 192.168.0.0
network 192.168.26.0
network 192.168.50.0
network 192.168.125.0
network 192.168.254.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/CME_GUI
ip nat inside source list 20 pool Internet overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/3/0 track 10
ip route 0.0.0.0 0.0.0.0 192.168.0.254 10 track 20
ip route 4.2.2.2 255.255.255.255 FastEthernet0/3/0
ip route 10.110.0.2 255.255.255.255 Service-Engine0/1
ip sla 1
icmp-echo 4.2.2.2 source-interface FastEthernet0/3/0
threshold 750
timeout 900
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 192.168.0.254 source-ip 192.168.0.253
threshold 750
timeout 900
frequency 1
ip sla schedule 2 life forever start-time now
logging esm config
logging history size 500
access-list 20 remark Networks Allowed onto the Internet
access-list 20 permit 192.168.0.0 0.0.255.255
access-list 20 permit 10.110.0.0 0.0.0.255
access-list 100 remark "Block access from the Guest network to everything except the printer & the Interent
access-list 100 permit ip any host 192.168.69.99
access-list 100 permit ip any 192.168.200.0 0.0.0.7
access-list 100 deny ip any 192.168.0.0 0.0.255.255
access-list 100 permit ip any any
7 Replies 7
Kelvin Willacey
Level 4
Level 4
Does the router get an IP address? Are you able to ping out? I also don't see the NAT pool "Internet" defined in the configuration that you are using to do NAT overload.
Yes, the router gets an IP address from the ISP, it is not a public IP.
I am not much on setting up NAT, I looked up some examples on the net but they may be missing some commands.  That may be the area that I need some help with.
OK in that case you don't need a NAT pool, you can simply overload on the interface.
no ip nat inside source list 20 pool Internet overload
ip nat inside source list 20 interface fastethernet0/3/0 overload
How many Internet connections do you currently have? You have "ip nat outside" on a single interface so I am thinking your tracking configuration is not required and can be removed.
My topology is more than shown.  I do need the SLA/TRAC as I use my neighbor's Internet should mine go down and vice versa.  Both of us use Verizon 4G to our networks.  His end is working perfectly.
I made those changes but still no luck.
TDC_CME_Router(config)#do sh trac
Track 10
IP SLA 1 reachability
Reachability is Down
629 changes, last change 07:45:20
Delay up 1 sec, down 1 sec
Latest operation return code: Timeout
Tracked by:
STATIC-IP-ROUTING 0
Track 20
IP SLA 2 reachability
Reachability is Up
16 changes, last change 4d06h
Latest operation return code: OK
Latest RTT (millisecs) 1
Tracked by:
STATIC-IP-ROUTING 0
TDC_CME_Router(config)#do ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
..U..
Well it would seem that you should be able to browse through the other link considering that the tracked object is down and Internet traffic will be routed to 192.168.0.254 so you might want to check to ensure that the other end is performing NAT your subnets.
Do a show dhcp lease to determine the default gateway and ensure that you have reach-ability to the gateway and a show ip int bri and show ip route. You might also want to change the static route to point to the next hop rather than the interface.
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/3/0 track 10
ip route 0.0.0.0 0.0.0.0 dhcp track 10
no ip route 4.2.2.2 255.255.255.255 FastEthernet0/3/0
ip route 4.2.2.2 255.255.255.255 dhcp
Michael Durham
Level 4
Level 4
I made some changes to the configuration above as per what I found on Cisco's web site for NAT.  But it still does not work.
I do get an IP address from the modem. 100.76.157.54 (Verizon's private IP address).  I was told to enter the command ip route 0.0.0.0 0.0.0.0 dhcp, this did give me a route in the routing table of 0.0.0.0 0.0.0.0 100.76.157.53 but nothing pings out. I can ping 100.76.157.54 but not 100.76.157.53.
The static route 4.2.2.2 255.255.255.255 fa0/3/0 is I can test the fa0/3/0 connection while still having Internet via my backup source.  Once fa0/3/0 is working , this will be removed.
I have two sources for accessing the Internet, fa0/3/0 and gi0/1.2 which is my neighbor's Internet connection.  This is why I need SLA and TRAC working.  BUT, I need to get off his Internet and onto mind via fa0/3/0.  BTW, I am his backup Internet should his go down.
Here is the latest config and some diag results:
! Last configuration change at 12:25:24 DST Fri Oct 14 2016 by mdurham
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime year
service password-encryption
service sequence-numbers
hostname TDC_CME_Router
boot-start-marker
boot-end-marker
logging buffered 10000000
enable secret 5 $1$0AMTNh1
no aaa new-model
clock timezone Eastern -5 0
clock summer-time DST recurring
dot11 syslog
ip source-route
ip cef
ip dhcp smart-relay
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Users
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Voice
dns-server 8.8.8.8
lease 0 12
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
domain-name thecorporation.com
no ipv6 cef
voice-card 0
license udi pid CISCO2851 sn FTX1517
username mdurham privilege 15 password 7 0520B5343
redundancy
delay down 1 up 1
delay down 1 up 1
no ip address
ip nat inside
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
no ip address
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat outside
ip nat enable
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
router eigrp 1577
network 192.168.0.0
ip http server
ip nat inside source list 20 interface FastEthernet0/3/0 overload
ip sla 1
threshold 750
timeout 900
frequency 1
ip sla 2
threshold 750
timeout 900
frequency 1
logging esm config
access-list 20 permit 192.168.0.0 0.0.0.255
access-list 20 permit 192.168.26.0 0.0.0.255
access-list 20 permit 192.168.27.0 0.0.0.255
access-list 20 permit 192.168.50.0 0.0.0.255
access-list 20 permit 192.168.69.0 0.0.0.255
access-list 20 permit 192.168.125.0 0.0.0.255
access-list 20 permit 192.168.200.0 0.0.0.255
TDC_CME_Router(config)#do sh ip int bri
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/0.26 192.168.26.1 YES NVRAM up up
GigabitEthernet0/0.50 192.168.50.1 YES NVRAM up up
Service-Engine0/1 10.110.0.1 YES unset up up
GigabitEthernet0/1 unassigned YES NVRAM up up
GigabitEthernet0/1.2 192.168.0.253 YES NVRAM up up
GigabitEthernet0/1.27 192.168.27.1 YES NVRAM up up
GigabitEthernet0/1.69 192.168.69.1 YES NVRAM up up
GigabitEthernet0/1.110 10.110.0.1 YES NVRAM up up
GigabitEthernet0/1.125 192.168.125.1 YES NVRAM up up
GigabitEthernet0/1.200 192.168.200.1 YES NVRAM up up
FastEthernet0/3/0 100.76.157.54 YES DHCP up up
GigabitEthernet1/0 192.168.70.1 YES manual up up
NVI0 100.76.157.54 YES unset administratively down down
TDC_CME_Router(config)#do sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 100.76.157.53 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 100.76.157.53
4.0.0.0/32 is subnetted, 1 subnets
S 4.2.2.2 is directly connected, FastEthernet0/3/0
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.110.0.0/24 is directly connected, GigabitEthernet0/1.110
L 10.110.0.1/32 is directly connected, GigabitEthernet0/1.110
S 10.110.0.2/32 is directly connected, Service-Engine0/1
100.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 100.76.157.52/30 is directly connected, FastEthernet0/3/0
L 100.76.157.54/32 is directly connected, FastEthernet0/3/0
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, GigabitEthernet0/1.2
L 192.168.0.253/32 is directly connected, GigabitEthernet0/1.2
192.168.10.0/32 is subnetted, 1 subnets
S 192.168.10.1 [254/0] via 100.76.157.53, FastEthernet0/3/0
192.168.26.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.26.0/24 is directly connected, GigabitEthernet0/0.26
L 192.168.26.1/32 is directly connected, GigabitEthernet0/0.26
192.168.27.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.27.0/24 is directly connected, GigabitEthernet0/1.27
L 192.168.27.1/32 is directly connected, GigabitEthernet0/1.27
192.168.50.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.50.0/24 is directly connected, GigabitEthernet0/0.50
L 192.168.50.1/32 is directly connected, GigabitEthernet0/0.50
192.168.69.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.69.0/24 is directly connected, GigabitEthernet0/1.69
L 192.168.69.1/32 is directly connected, GigabitEthernet0/1.69
192.168.70.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.70.0/24 is directly connected, GigabitEthernet1/0
L 192.168.70.1/32 is directly connected, GigabitEthernet1/0
192.168.125.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.125.0/24 is directly connected, GigabitEthernet0/1.125
L 192.168.125.1/32 is directly connected, GigabitEthernet0/1.125
192.168.200.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.200.0/24 is directly connected, GigabitEthernet0/1.200
L 192.168.200.1/32 is directly connected, GigabitEthernet0/1.200
TDC_CME_Router(config)#do ping 8.8.8.8 source 192.168.69.1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 192.168.69.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/62/76 ms
TDC_CME_Router(config)#do ping 8.8.8.8 source 192.168.200.1
Packet sent with a source address of 192.168.200.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/50/64 ms
TDC_CME_Router(config)#do ping 8.8.8.8 source 100.76.157.54
Packet sent with a source address of 100.76.157.54
TDC_CME_Router#sh ip int fa0/3/0
FastEthernet0/3/0 is up, line protocol is up
  Internet address is 100.76.157.54/30
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is disabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is disabled
  IP Null turbo vector
  IP multicast fast switching is disabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are No CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
  Output features: Post-routing NAT NVI Output, Post-routing NAT Outside, Stateful Inspection, NAT ALG proxy
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
TDC_CME_Router#sh ip nat statistics
Total active translations: 515 (0 static, 515 dynamic; 515 extended)
Peak translations: 515, occurred 00:00:00 ago
Outside interfaces:
  FastEthernet0/3/0
Inside interfaces:
  GigabitEthernet0/0, GigabitEthernet0/0.26, GigabitEthernet0/0.50
  Service-Engine0/1, GigabitEthernet0/1.2, GigabitEthernet0/1.27
  GigabitEthernet0/1.69, GigabitEthernet0/1.110, GigabitEthernet0/1.125
  GigabitEthernet0/1.200, GigabitEthernet1/0
Hits: 20060  Misses: 0
CEF Translated packets: 4855, CEF Punted packets: 7858
Expired translations: 6934
Dynamic mappings:
-- Inside Source
[Id: 3] access-list 20 interface FastEthernet0/3/0 refcount 515
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
TDC_CME_Router#sh ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
udp 100.76.157.54:51425   192.168.50.50:51425   8.8.8.8:53            8.8.8.8:53
udp 100.76.157.54:56490   192.168.50.50:56490   4.2.2.2:53            4.2.2.2:53
udp 100.76.157.54:54520   192.168.50.100:54520  4.2.2.2:53            4.2.2.2:53
udp 100.76.157.54:54520   192.168.50.100:54520  8.8.8.8:53            8.8.8.8:53
udp 100.76.157.54:54685   192.168.50.100:54685  128.8.10.90:53        128.8.10.90:53
udp 100.76.157.54:55025   192.168.50.100:55025  193.0.14.129:53       193.0.14.129:53
udp 100.76.157.54:55115   192.168.50.100:55115  4.2.2.2:53            4.2.2.2:53
udp 100.76.157.54:55115   192.168.50.100:55115  8.8.8.8:53            8.8.8.8:53
udp 100.76.157.54:56221   192.168.50.100:56221  192.36.148.17:53      192.36.148.17:53
udp 100.76.157.54:56272   192.168.50.100:56272  4.2.2.2:53            4.2.2.2:53
udp 100.76.157.54:56272   192.168.50.100:56272  8.8.8.8:53            8.8.8.8:53
icmp 100.76.157.54:20313  192.168.69.3:20313    4.2.2.2:20313         4.2.2.2:20313
udp 100.76.157.54:41639   192.168.69.69:41639   8.8.8.8:53            8.8.8.8:53
TDC_CME_Router#sh ip nat nvi translations
Pro Source global         Source local          Destin  local         Destin  global
TDC_CME_Router#sh ip nat nvi statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
NAT Enabled interfaces:
  FastEthernet0/3/0
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
