IPv4 VRF based iBGP on cisco router
rabbee
Hi, I want to configure IPv4 vrf based iBGP peering between CE router to another CE router to forward only specific client traffic via MW path to the aggregation.
You can do that if SP allow ibgp between CE and PE.
DanielP211
Hello!
Do you want some sample configuration for this? Or what is the question? If its possible? It is possible.
BR
****Kindly rate all useful posts*****
Hi Daniel, yes it will help me I guess If got the configuration sample. I will let you know if face any other problem.
Thanks.
the CE-PE usually run eBGP not iBGP
and for eBGP VRF it simple
PE already run VRF in BGP config for CE
you need to use same VRF name in config of BGP in CE
