Cisco IOS XE & IOS vulnerabilites patches
Mohammed.MY
Hello Guys,
I'm looking for Cisco vulnerability patches, what I can see is links that redirected to pages with huge content.
For example if I have below links which cisco devices are vulnerable with software. I read and analyzed but i didn't follow exactly. I need some help in detail. Please help me out. I want to find the patches.
https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-webui-cmdij-FzZAeXAy
https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-mlre-H93FswRz
https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-ios-xe-l2tp-dos-eB5tuFmV
https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-nxos-remoteauth-dos-XB6pv74m
3 Accepted Solutions
ammahend
click on the Cisco bug IDs, then scroll down to known fixed releases, you need to upgrade to those version.
-hope this helps-
balaji.bandi
Depends on the device and IOS code running on the device. eash PSIRT have tagged with bug ID, if you search with BUG ID, then cisco advice what version required or upgrade to fix the issue example below :
BB
ammahend
-hope this helps-
balaji.bandi
BB
Mohammed.MY
Can you confirm, if this correct
