IPv6 Multicast mroute question
gongya001
Level 5
Level 5
I am trying to lab IPv6 Multicast. But when I run the command, but I got the following:
R1(config)#do show ipv6 mroute
No mroute entries found.
I tried on Cisco2811 and Cisco 6500.
I enabled ipv6 multicast-routing.
Anything have I missed or the platform I tried on does not support IPv6 mroute ?
thanks !!
Is your source transmitting packets to the multicast group? If not, R1 will not see any entry in the multicast routing table.
5 Replies 5
Georg Pauwen
hard to say what you are missing, can you post the full configs ? What is the output of 'show ipv6 mrib route summary' ?
hostname R1
ipv6 uni
int lo0
  ipv6 add 2001::1:1:1:1/128
int e0/0
  ipv6 add 2001:192:168::1/64
  ipv6 en
  no shut
int e0/1
  ipv6 add 2001:172:16:13::1/64
  ipv6 en
  no shut
int e0/2
  ipv6 add 2001:172:16:14::1/64
  ipv6 en
  no shut
router eigrp CCIE
  add ipv6 auto 10
    eigrp router-id 1.1.1.1
R1#show ipv6 mroute summary
R1#show ipv6 mroute
R1#show ipv6 pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, G - GenID Capable
Neighbor Address           Interface          Uptime    Expires  Mode DR pri
FE80::A8BB:CCFF:FE00:600   Ethernet0/0        23:14:41  00:01:35 B G  DR 1
FE80::A8BB:CCFF:FE00:310   Ethernet0/1        17:06:27  00:01:23 B G  DR 1
FE80::A8BB:CCFF:FE00:420   Ethernet0/2        17:03:43  00:01:22 B G  DR 1
thanks !!
thanks !  I will double check it.
thanks a lot !!
Mroute shows routes after I sent some multicast traffic.
