IPv6 static routes, no ping!
josgutsacr
I have two routers directly connected. I can ping the interfaces IP addres, but can´t ping between loopbacks.
Thks
9 Replies 9
cadet alain
can you do debug ipv6 pack det on left device then ping the loop of right device and post the log output.
Regards.
Alain
R1#debug ipv6 packet detail
  IPv6 unicast packet debugging is on
R1#ping 2803:6000:4::1
Sending 5, 100-byte ICMP Echos to 2803:6000:4::1, timeout is 2 seconds:
Oct 22 11:45:32.933 UTC: IPv6-Fwd: Destination lookup for 2803:6000:4::1 : i/f=GigabitEthernet1/14, nexthop=2803:6000:3::2
Oct 22 11:45:32.933 UTC: IPv6-Sas: SAS picked source 2803:6000:3::1 for 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:32.933 UTC: IPv6-Fwd: nexthop 2803:6000:3::2,
Oct 22 11:45:32.933 UTC: IPV6: source 2803:6000:3::1 (local)
Oct 22 11:45:32.933 UTC:       dest 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:32.933 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 11:45:32.933 UTC: IPv6-Fwd: Created tmp mtu cache entry for 2803:6000:3::1 2803:6000:4::1 00000000
Oct 22 11:45:32.933 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14.
Oct 22 11:45:34.934 UTC: IPv6-Fwd: Destination lookup for 2803:6000:4::1 : i/f=GigabitEthernet1/14, nexthop=2803:6000:3::2
Oct 22 11:45:34.934 UTC: IPv6-Sas: SAS picked source 2803:6000:3::1 for 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:34.934 UTC: IPv6-Fwd: nexthop 2803:6000:3::2,
Oct 22 11:45:34.934 UTC: IPV6: source 2803:6000:3::1 (local)
Oct 22 11:45:34.934 UTC:       dest 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:34.934 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 11:45:34.934 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14.
Oct 22 11:45:36.934 UTC: IPv6-Fwd: Destination lookup for 2803:6000:4::1 : i/f=GigabitEthernet1/14, nexthop=2803:6000:3::2
Oct 22 11:45:36.934 UTC: IPv6-Sas: SAS picked source 2803:6000:3::1 for 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:36.934 UTC: IPv6-Fwd: nexthop 2803:6000:3::2,
Oct 22 11:45:36.934 UTC: IPV6: source 2803:6000:3::1 (local)
Oct 22 11:45:36.934 UTC:       dest 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:36.934 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 11:45:36.934 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14
Oct 22 11:45:38.026 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:45:38.026 UTC:       dest 2803:6000:3::2 (GigabitEthernet1/14)
Oct 22 11:45:38.026 UTC:       traffic class 224, flow 0x0, len 72+0, prot 58, hops 255, originating
Oct 22 11:45:38.026 UTC: IPv6-Fwd: Created tmp mtu cache entry for FE80::223:4FF:FE17:9780 2803:6000:3::2 00000000
Oct 22 11:45:38.026 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14
Oct 22 11:45:38.034 UTC: IPv6-Fwd: Destination lookup for FE80::223:4FF:FE17:9780 : Local, i/f=GigabitEthernet1/14, nexthop=FE80::223:4FF:FE17:9780
Oct 22 11:45:38.034 UTC: IPV6: source 2803:6000:3::2 (GigabitEthernet1/14).
Oct 22 11:45:38.034 UTC:       dest FE80::223:4FF:FE17:9780 (GigabitEthernet1/14)
Oct 22 11:45:38.034 UTC:       traffic class 0, flow 0x0, len 64+14, prot 58, hops 255, forward to ulp
Oct 22 11:45:38.934 UTC: IPv6-Fwd: Destination lookup for 2803:6000:4::1 : i/f=GigabitEthernet1/14, nexthop=2803:6000:3::2
Oct 22 11:45:38.934 UTC: IPv6-Sas: SAS picked source 2803:6000:3::1 for 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:38.934 UTC: IPv6-Fwd: nexthop 2803:6000:3::2,
Oct 22 11:45:38.934 UTC: IPV6: source 2803:6000:3::1 (local)
Oct 22 11:45:38.934 UTC:       dest 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:38.934 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 11:45:38.934 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14
Oct 22 11:45:39.567 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:45:39.567 UTC:       dest FF02::1 (TenGigabitEthernet9/4.41)
Oct 22 11:45:39.567 UTC:       traffic class 224, flow 0x0, len 104+0, prot 58, hops 255, originating
Oct 22 11:45:39.567 UTC: IPv6-Fwd: Sending on TenGigabitEthernet9/4.41.
Oct 22 11:45:40.935 UTC: IPv6-Fwd: Destination lookup for 2803:6000:4::1 : i/f=GigabitEthernet1/14, nexthop=2803:6000:3::2
Oct 22 11:45:40.935 UTC: IPv6-Sas: SAS picked source 2803:6000:3::1 for 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:40.935 UTC: IPv6-Fwd: nexthop 2803:6000:3::2,
Oct 22 11:45:40.935 UTC: IPV6: source 2803:6000:3::1 (local)
Oct 22 11:45:40.935 UTC:       dest 2803:6000:4::1 (GigabitEthernet1/14)
Oct 22 11:45:40.935 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 11:45:40.935 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14.
Success rate is 0 percent (0/5)
R1#
Oct 22 11:45:42.771 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:45:42.771 UTC:       dest FF02::1 (GigabitEthernet1/14)
Oct 22 11:45:42.771 UTC:       traffic class 224, flow 0x0, len 104+0, prot 58, hops 255, originating
Oct 22 11:45:42.771 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14
Oct 22 11:45:43.075 UTC: IPv6-Fwd: Destination lookup for FE80::223:4FF:FE17:9780 : Local, i/f=GigabitEthernet1/14, nexthop=FE80::223:4FF:FE17:9780
Oct 22 11:45:43.075 UTC: IPV6: source FE80::226:99FF:FEFD:3152 (GigabitEthernet1/14)
Oct 22 11:45:43.075 UTC:       dest FE80::223:4FF:FE17:9780 (GigabitEthernet1/14)
Oct 22 11:45:43.075 UTC:       traffic class 0, flow 0x0, len 72+14, prot 58, hops 255, forward to ulp
Oct 22 11:45:43.079 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:45:43.079 UTC:       dest FE80::226:99FF:FEFD:3152 (GigabitEthernet1/14)
Oct 22 11:45:43.079 UTC:       traffic class 224, flow 0x0, len 64+0, prot 58, hops 255, originating
Oct 22 11:45:43.079 UTC: IPv6-Fwd: Created tmp mtu cache entry for FE80::223:4FF:FE17:9780 FE80::226:99FF:FEFD:3152 00000000
Oct 22 11:45:43.079 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14
Oct 22 11:45:48.149 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:45:48.149 UTC:       dest FE80::226:99FF:FEFD:3152 (GigabitEthernet1/14)
Oct 22 11:45:48.149 UTC:       traffic class 224, flow 0x0, len 72+0, prot 58, hops 255, originating
Oct 22 11:45:48.149 UTC: IPv6-Fwd: Sending on GigabitEthernet1/14
Oct 22 11:45:48.153 UTC: IPv6-Fwd: Destination lookup for FE80::223:4FF:FE17:9780 : Local, i/f=GigabitEthernet1/14, nexthop=FE80::223:4FF:FE17:9780
Oct 22 11:45:48.153 UTC: IPV6: source FE80::226:99FF:FEFD:3152 (GigabitEthernet1/14)
Oct 22 11:45:48.153 UTC:       dest FE80::223:4FF:FE17:9780 (GigabitEthernet1/14)
Oct 22 11:45:48.153 UTC:       traffic class 0, flow 0x0, len 64+14, prot 58, hops 255, forward to ulp
Oct 22 11:46:00.031 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:46:00.031 UTC:       dest FF02::1 (GigabitEthernet1/24)
Oct 22 11:46:00.031 UTC:       traffic class 224, flow 0x0, len 104+0, prot 58, hops 255, originating
Oct 22 11:46:00.031 UTC: IPv6-Fwd: Sending on GigabitEthernet1/24
Oct 22 11:46:59.983 UTC: IPV6: source FE80::225:84FF:FE7B:7800 (TenGigabitEthernet9/4.41)
Oct 22 11:46:59.983 UTC:       dest FF02::1
Oct 22 11:46:59.983 UTC:       traffic class 224, flow 0x0, len 104+14, prot 58, hops 255, forward to ulp
Oct 22 11:47:07.804 UTC: IPV6: source FE80::226:99FF:FEFD:3152 (GigabitEthernet1/14)
Oct 22 11:47:07.804 UTC:       dest FF02::1
Oct 22 11:47:07.804 UTC:       traffic class 0, flow 0x0, len 104+14, prot 58, hops 255, forward to ulp
Oct 22 11:47:10.818 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:47:10.818 UTC:       dest FF02::1 (VRF_16_vlan1027)
Oct 22 11:47:10.818 UTC:       traffic class 224, flow 0x0, len 72+0, prot 58, hops 255, originating
Oct 22 11:47:10.818 UTC: IPv6-Fwd: Sending on VRF_16_vlan1027
Oct 22 11:48:05.031 UTC: IPV6: source FE80::227:CFF:FE55:7C1B (GigabitEthernet1/24)
Oct 22 11:48:05.031 UTC:       dest FF02::1
Oct 22 11:48:05.031 UTC:       traffic class 224, flow 0x0, len 104+14, prot 58, hops 255, forward to ulp
Oct 22 11:48:16.034 UTC: IPV6: source FE80::223:4FF:FE17:9780 (local)
Oct 22 11:48:16.034 UTC:       dest FF02::1 (TenGigabitEthernet9/4.41)
Oct 22 11:48:16.034 UTC:       traffic class 224, flow 0x0, len 104+0, prot 58, hops 255, originating
Oct 22 11:48:16.034 UTC: IPv6-Fwd: Sending on TenGigabitEthernet9/4.41
ok so the packets are sent out the correct interface and with correct next-hop.
Can you do the same debug on the other end while pinging from here and post output ?
Regards.
Alain
If I do ping without specif souce, it successful, (blue), but if I do ping with souce lo10 isunsuccessful (red)
R2# ping 2803:6000:1::1
Sending 5, 100-byte ICMP Echos to 2803:6000:1::1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/3/8 ms
R2#
Oct 22 12:19:10.911 UTC: IPv6-Fwd: Destination lookup for 2803:6000:1::1 : i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::1
Oct 22 12:19:10.911 UTC: IPv6-Sas: SAS picked source 2803:6000:3::2 for 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.911 UTC: IPv6-Fwd: nexthop 2803:6000:3::1,
Oct 22 12:19:10.911 UTC: IPV6: source 2803:6000:3::2 (local)
Oct 22 12:19:10.911 UTC:       dest 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.911 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 12:19:10.911 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 12:19:10.911 UTC: IPv6-Fwd: Destination lookup for 2803:6000:3::2 : Local, i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::2
Oct 22 12:19:10.911 UTC: IPV6: source 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.911 UTC:       dest 2803:6000:3::2 (GigabitEthernet1/1/1)
Oct 22 12:19:10.920 UTC:       traffic class 0, flow 0x0, len 100+14, prot 58, hops 64, forward to ulp
Oct 22 12:19:10.920 UTC: IPv6-Fwd: Destination lookup for 2803:6000:1::1 : i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::1
Oct 22 12:19:10.920 UTC: IPv6-Sas: SAS picked source 2803:6000:3::2 for 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.920 UTC: IPv6-Fwd: nexthop 2803:6000:3::1,
Oct 22 12:19:10.920 UTC: IPV6: source 2803:6000:3::2 (local)
Oct 22 12:19:10.920 UTC:       dest 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.920 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 12:19:10.920 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 12:19:10.920 UTC: IPv6-Fwd: Destination lookup for 2803:6000:3::2 : Local, i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::2
Oct 22 12:19:10.920 UTC: IPV6: source 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.920 UTC:       dest 2803:6000:3::2 (GigabitEthernet1/1/1)
Oct 22 12:19:10.928 UTC: IPv6-Fwd: Destination lookup for 2803:6000:1::1 : i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::1
Oct 22 12:19:10.928 UTC: IPv6-Sas: SAS picked source 2803:6000:3::2 for 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.928 UTC: IPv6-Fwd: nexthop 2803:6000:3::1,
Oct 22 12:19:10.928 UTC: IPV6: source 2803:6000:3::2 (local)
Oct 22 12:19:10.928 UTC:       dest 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.928 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 12:19:10.928 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 12:19:10.928 UTC: IPv6-Fwd: Destination lookup for 2803:6000:3::2 : Local, i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::2
Oct 22 12:19:10.928 UTC: IPV6: source 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:19:10.928 UTC:       dest 2803:6000:3::2 (GigabitEthernet1/1/1)
Oct 22 12:19:10.928 UTC:       traffic class 0, flow 0x0, len 100+14, prot 58, hops 64, forward to ulp
R2# ping 2803:6000:1::1 source lo 10
Packet sent with a source address of 2803:6000:4::1
Oct 22 12:22:06.879 UTC: IPv6-Sas: SAS on intf Loopback10 picked source 2803:6000:4::1 for 2803:6000:1::1
Oct 22 12:22:06.879 UTC: IPv6-Fwd: Destination lookup for 2803:6000:1::1 : i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::1
Oct 22 12:22:06.879 UTC: IPv6-Fwd: nexthop 2803:6000:3::1,
Oct 22 12:22:06.879 UTC: IPV6: source 2803:6000:4::1 (local)
Oct 22 12:22:06.879 UTC:       dest 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:22:06.879 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 12:22:06.879 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1.
Oct 22 12:22:08.884 UTC: IPv6-Fwd: Destination lookup for 2803:6000:1::1 : i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::1
Oct 22 12:22:08.884 UTC: IPv6-Fwd: nexthop 2803:6000:3::1,
Oct 22 12:22:08.884 UTC: IPV6: source 2803:6000:4::1 (local)
Oct 22 12:22:08.884 UTC:       dest 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:22:08.884 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 12:22:08.884 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1.
Oct 22 12:22:10.889 UTC: IPv6-Fwd: Destination lookup for 2803:6000:1::1 : i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::1
Oct 22 12:22:10.889 UTC: IPv6-Fwd: nexthop 2803:6000:3::1,
Oct 22 12:22:10.889 UTC: IPV6: source 2803:6000:4::1 (local)
Oct 22 12:22:10.889 UTC:       dest 2803:6000:1::1 (GigabitEthernet1/1/1)
Oct 22 12:22:10.889 UTC:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
Oct 22 12:22:10.889 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 12:22:11.912 UTC: IPV6: source FE80::226:99FF:FEFD:3152 (local)
Oct 22 12:22:11.912 UTC:       dest 2803:6000:3::1 (GigabitEthernet1/1/1)
Oct 22 12:22:11.912 UTC:       traffic class 224, flow 0x0, len 72+0, prot 58, hops 255, originating
Oct 22 12:22:11.912 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 12:22:11.912 UTC: IPv6-Fwd: Destination lookup for FE80::226:99FF:FEFD:3152 : Local, i/f=GigabitEthernet1/1/1, nexthop=FE80::226:99FF:FEFD:3152
Oct 22 12:22:11.912 UTC: IPV6: source 2803:6000:3::1 (GigabitEthernet1/1/1)
El mensaje fue editado por: Jose Gutierrez salazar
ok but i would have liked to get the output on R2 when pinging from R1.
Can you do this also? because you were pinging from Lo interface on r1 also when unsuccessful ?
Regards.
Alain
Ping from R1, the following output is from R2.
Oct 22 13:51:29.674 UTC: IPv6-Fwd: Destination lookup for 2803:6000:3::2 : Local, i/f=GigabitEthernet1/1/1, nexthop=2803:6000:3::2
Oct 22 13:51:29.674 UTC: IPV6: source FE80::223:4FF:FE17:9780 (GigabitEthernet1/1/1)
Oct 22 13:51:29.674 UTC:       dest 2803:6000:3::2 (GigabitEthernet1/1/1)
Oct 22 13:51:29.674 UTC:       traffic class 224, flow 0x0, len 72+14, prot 58, hops 255, forward to ulp
Oct 22 13:51:29.682 UTC: IPV6: source 2803:6000:3::2 (local)
Oct 22 13:51:29.682 UTC:       dest FE80::223:4FF:FE17:9780 (GigabitEthernet1/1/1)
Oct 22 13:51:29.682 UTC:       traffic class 224, flow 0x0, len 64+0, prot 58, hops 255, originating
Oct 22 13:51:29.682 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 13:51:34.724 UTC: IPV6: source FE80::226:99FF:FEFD:3152 (local)
Oct 22 13:51:34.724 UTC:       dest FE80::223:4FF:FE17:9780 (GigabitEthernet1/1/1)
Oct 22 13:51:34.724 UTC:       traffic class 224, flow 0x0, len 72+0, prot 58, hops 255, originating
Oct 22 13:51:34.724 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
Oct 22 13:51:34.724 UTC: IPv6-Fwd: Destination lookup for FE80::226:99FF:FEFD:3152 : Local, i/f=GigabitEthernet1/1/1, nexthop=FE80::226:99FF:FEFD:3152
Oct 22 13:51:34.724 UTC: IPV6: source FE80::223:4FF:FE17:9780 (GigabitEthernet1/1/1)
Oct 22 13:51:34.724 UTC:       dest FE80::226:99FF:FEFD:3152 (GigabitEthernet1/1/1)
Oct 22 13:51:34.724 UTC:       traffic class 224, flow 0x0, len 64+14, prot 58, hops 255, forward to ulp
Oct 22 13:51:39.782 UTC: IPv6-Fwd: Destination lookup for FE80::226:99FF:FEFD:3152 : Local, i/f=GigabitEthernet1/1/1, nexthop=FE80::226:99FF:FEFD:3152
Oct 22 13:51:39.782 UTC: IPV6: source FE80::223:4FF:FE17:9780 (GigabitEthernet1/1/1)
Oct 22 13:51:39.782 UTC:       dest FE80::226:99FF:FEFD:3152 (GigabitEthernet1/1/1)
Oct 22 13:51:39.790 UTC:       traffic class 224, flow 0x0, len 72+14, prot 58, hops 255, forward to ulp
Oct 22 13:51:39.799 UTC: IPV6: source FE80::226:99FF:FEFD:3152 (local)
Oct 22 13:51:39.799 UTC:       dest FE80::223:4FF:FE17:9780 (GigabitEthernet1/1/1)
Oct 22 13:51:39.799 UTC:       traffic class 224, flow 0x0, len 64+0, prot 58, hops 255, originating
Oct 22 13:51:39.799 UTC: IPv6-Fwd: Sending on GigabitEthernet1/1/1
can you redo a ping from R1 to R2 loopback then from R1 sourcing from Loopback to R2 Loopback while disabling debug for ipv6 packet and enabling debug ipv6 icmp on both sides and post results.
Regards.
Alain
The ping was unsuccessful.
R1#ping 2803:6000:4::1 source loopback 10
Packet sent with a source address of 2803:6000:1::1
Oct 23 08:32:43.336 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1.
Oct 23 08:32:45.337 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1.
Oct 23 08:32:47.338 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1.
Oct 23 08:32:48.367 UTC: ICMPv6: Sent N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=2803:6000:3::2
Oct 23 08:32:48.371 UTC: ICMPv6: Received N-Advert, Src=2803:6000:3::2, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:32:49.339 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1.
Oct 23 08:32:51.340 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1.
-->output from R2, during the ping from R1
R2#
Oct 23 08:32:28.765 UTC: ICMPv6: Sent R-Advert, Src=FE80::226:99FF:FEFD:3152, Dst=FF02::1
Oct 23 08:32:47.991 UTC: ICMPv6: Received N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=2803:6000:3::2
Oct 23 08:32:48.000 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::2, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:32:53.041 UTC: ICMPv6: Sent N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:32:53.041 UTC: ICMPv6: Received N-Advert, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:32:58.100 UTC: ICMPv6: Received N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:32:58.108 UTC: ICMPv6: Sent N-Advert, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:32:58.385 UTC: ICMPv6: Sent R-Advert, Src=FE80::226:99FF:FEFD:3156, Dst=FF02::1
R2#ping 2803:6000:1::1 source loopback 10
Oct 23 08:30:02.308 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:30:02.317 UTC: ICMPv6: Received N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=FF02::1:FF00:2
Oct 23 08:30:02.325 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::2, Dst=FE80::223:4FF:FE17:9780.
Oct 23 08:30:04.313 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1.
Oct 23 08:30:06.318 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1.
Oct 23 08:30:07.366 UTC: ICMPv6: Sent N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=2803:6000:3::1
Oct 23 08:30:07.366 UTC: ICMPv6: Received N-Advert, Src=2803:6000:3::1, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:07.442 UTC: ICMPv6: Sent N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:30:07.442 UTC: ICMPv6: Received N-Advert, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:08.323 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1.
Oct 23 08:30:10.328 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1.
-->output from R1 during the ping from R2
R1#
Oct 23 08:29:37.480 UTC: ICMPv6: Received R-Advert, Src=FE80::227:CFF:FE55:7C1B, Dst=FF02::1
Oct 23 08:30:02.605 UTC: ICMPv6: Received echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:30:02.605 UTC: ICMPv6: Sent echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:30:02.609 UTC: ICMPv6: Sent N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=FF02::1:FF00:2
Oct 23 08:30:02.613 UTC: ICMPv6: Received N-Advert, Src=2803:6000:3::2, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:30:04.602 UTC: ICMPv6: Received echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:30:04.606 UTC: ICMPv6: Sent echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:30:06.611 UTC: ICMPv6: Received echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:30:06.611 UTC: ICMPv6: Sent echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:30:07.659 UTC: ICMPv6: Received N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=2803:6000:3::1
Oct 23 08:30:07.663 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::1, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:07.731 UTC: ICMPv6: Received N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:30:07.735 UTC: ICMPv6: Sent N-Advert, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:08.616 UTC: ICMPv6: Received echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:30:08.616 UTC: ICMPv6: Sent echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:30:10.625 UTC: ICMPv6: Received echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:30:10.625 UTC: ICMPv6: Sent echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:30:12.738 UTC: ICMPv6: Sent N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:12.746 UTC: ICMPv6: Received N-Advert, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:30:20.730 UTC: ICMPv6: Received R-Advert, Src=FE80::225:84FF:FE7B:7800, Dst=FF02::1
Oct 23 08:30:27.701 UTC: ICMPv6: Sent R-Advert, Src=FE80::223:4FF:FE17:9780, Dst=FF02::1
Oct 23 08:30:49.448 UTC: ICMPv6: Received N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=2803:6000:3::1
Oct 23 08:30:49.452 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::1, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:50.460 UTC: ICMPv6: Received N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:30:50.464 UTC: ICMPv6: Sent N-Advert, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:54.566 UTC: ICMPv6: Sent N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
Oct 23 08:30:54.574 UTC: ICMPv6: Received N-Advert, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
I fixed an interface vlan with ipv6 address 2803:6000:15::1/48. I had good results from both routers, but I don´t understand, what is the difference?
I also placed the same loopback ip add in the same interface vlan and was working (at the end)
It seems like it doesn´t work with interface loopback, this happens only at 3750me.
R2#ping 2803:6000:1::1 source vlan 56
Packet sent with a source address of 2803:6000:15::1
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/1/9 ms
R2#
Oct 23 08:48:36.070 UTC: ICMPv6: Sent echo request, Src=2803:6000:15::1, Dst=2803:6000:1::1
Oct 23 08:48:36.070 UTC: ICMPv6: Received echo reply, Src=2803:6000:1::1, Dst=2803:6000:15::1
Oct 23 08:48:36.079 UTC: ICMPv6: Sent echo request, Src=2803:6000:15::1, Dst=2803:6000:1::1
Oct 23 08:48:36.079 UTC: ICMPv6: Received echo reply, Src=2803:6000:1::1, Dst=2803:6000:15::1
Oct 23 08:48:41.129 UTC: ICMPv6: Received N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=2803:6000:3::2
Oct 23 08:48:41.137 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::2, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:48:46.179 UTC: ICMPv6: Sent N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=FE80::223:4FF:FE17:9780
Oct 23 08:48:46.187 UTC: ICMPv6: Received N-Advert, Src=FE80::223:4FF:FE17:9780, Dst=FE80::226:99FF:FEFD:3152
R1#ping 2803:6000:15::1 source loopback 10
Sending 5, 100-byte ICMP Echos to 2803:6000:15::1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
R1#
Oct 23 08:50:52.744 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:15::1
Oct 23 08:50:52.748 UTC: ICMPv6: Received echo reply, Src=2803:6000:15::1, Dst=2803:6000:1::1
Oct 23 08:50:52.748 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:15::1
Oct 23 08:50:52.752 UTC: ICMPv6: Received echo reply, Src=2803:6000:15::1, Dst=2803:6000:1::1
Oct 23 08:50:52.752 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:15::1
Oct 23 08:50:52.756 UTC: ICMPv6: Received echo reply, Src=2803:6000:15::1, Dst=2803:6000:1::1
Oct 23 08:50:52.756 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:15::1
Oct 23 08:50:57.835 UTC: ICMPv6: Received N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=2803:6000:3::1
Oct 23 08:50:57.839 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::1, Dst=FE80::226:99FF:FEFD:3152
R2#sh run int lo 10
Building configuration...
Current configuration : 75 bytes
interface Loopback10
no ip address
ipv6 address 2803:6000:4::1/48
end
R2#conf
R2#configure
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#no interface Loopback10
R2(config)#int vla 56
R2(config-if)# ipv6 address 2803:6000:4::1/48
R2(config-if)#exit
R2(config)#do sh run int vlan 56
Current configuration : 167 bytes
interface Vlan56
ipv6 enable
end
R1#
Oct 23 08:56:22.324 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:56:22.328 UTC: ICMPv6: Received echo reply, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:56:22.328 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:56:22.332 UTC: ICMPv6: Received echo reply, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:56:22.332 UTC: ICMPv6: Sent echo request, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:56:22.336 UTC: ICMPv6: Received echo reply, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:56:27.371 UTC: ICMPv6: Received N-Solicit, Src=FE80::226:99FF:FEFD:3152, Dst=2803:6000:3::1
Oct 23 08:56:27.375 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::1, Dst=FE80::226:99FF:FEFD:3152
R2#ping 2803:6000:1::1 source 2803:6000:4::1
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/1/8 ms
R2#
Oct 23 08:57:33.972 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:57:33.972 UTC: ICMPv6: Received echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:57:33.981 UTC: ICMPv6: Received echo reply, Src=2803:6000:1::1, Dst=2803:6000:4::1
Oct 23 08:57:33.981 UTC: ICMPv6: Sent echo request, Src=2803:6000:4::1, Dst=2803:6000:1::1
Oct 23 08:57:39.014 UTC: ICMPv6: Received N-Solicit, Src=FE80::223:4FF:FE17:9780, Dst=2803:6000:3::2
Oct 23 08:57:39.022 UTC: ICMPv6: Sent N-Advert, Src=2803:6000:3::2, Dst=FE80::223:4FF:FE17:9780
