T1 on 3925 wont come up, data-coding inverted needed on 3660
jmweber12
We are currently trying to move all our P2P T1's from multiple 3600's to one 3925 in our data center. The offsite has a 2811 with data-coding inversion on it connects to our data center on a 3660 and is up. When I move it to our 3925, data-coding inverted isnt an option so we disabled on the 2811, we cant get the t1 to come up on the 3925.
Full T1 from from the 2811 to the NIU, comes into our data center on a ds3 into an adtran mux we manage. ATT confirmed ESF, B8ZS, our Adtran is set the same. Several other T1's come in on the DS3 to the 3925 and are up.
Below is the config and inv:
2811
c2800nm-advsecurityk9-mz.124-3g.bin
NAME: "WAN Interface Card - DSU/CSU T1 Fractional (V2)", DESCR: "WAN Interface C        ard - DSU/CSU T1 Fractional (V2)"
PID:                   , VID: 1.2,
interface Serial0/0/0
ip address x.x.x.x 255.255.255.252
ip nbar protocol-discovery
ip route-cache flow
load-interval 30
service-module t1 data-coding inverted
service-module t1 remote-alarm-enable
service-module t1 fdl ansi
CURRENTLY CONNECTED TO:
Cisco 3660
c3660-js-mz.123-14.T2.bin
NAME: "WAN Interface Card - DSU/CSU T1 Fractional", DESCR: "WAN Interface Card - DSU/CSU T1 Fractional"
PID:                   , VID: 1.3,
interface Serial4/0
ip route-cache flow
service-module t1 clock source internal
end
MOVING TO:
Cisco 3925
c3900-universalk9-mz.SPA.151-3.T1.bin"
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1  , VID: V01 ,
controller T1 0/1/0
cablelength short 110
channel-group 0 timeslots 1-24
interface Serial0/1/0:0
ip flow ingress
load-interval 30
end
5 Replies 5
paolo bevilacqua
Post "show controllers T1".
2811#sho service-module serial 0/0/0
Module type is T1/fractional
    Hardware revision is 1.2, Software revision is 20061106,
    Image checksum is 0x3E88B0, Protocol revision is 0.1
Receiver has no alarms.
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Fraction has 24 timeslots (64 Kbits/sec each), Net bandwidth is 1536 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 2w4d
    loss of signal        :    0,
    loss of frame         :    0,
    AIS alarm             :    0,
    Remote alarm          :    3, last occurred 1w6d
    Module access errors  :    0,
Total Data (last 96 15 minute intervals):
    0 Line Code Violations, 0 Path Code Violations
    0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in current interval (533 seconds elapsed):
3660-1#sho service-module serial 4/0
    Hardware revision is 0.96, Software revision is 20040131-0.3,
    Image checksum is 0x873E3B7E, Protocol revision is 0.1
Framing is ESF, Line Code is B8ZS, Current clock source is internal,
Last clearing of alarm counters 36w0d
    loss of signal        :    7, last occurred 1w6d
    loss of frame         :    8, last occurred 1w6d
    AIS alarm             :    1, last occurred 14w0d
    Remote alarm          :    3, last occurred 2w4d
Data in current interval (217 seconds elapsed):
3925
T1 0/1/0 is down.
  Applique type is Channelized T1
  Cablelength is short 110
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Failure LOF State:Failure
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (850 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 850 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
3925 should have clock source line, not internal.
Need to see show controllers T1 when cable is connected.
Note: for good results do not use ethernet patch cables. Use proper T1 100 Ohm cable, if that osnot available, use Cat5 and crimp pairs correctty per T1 pinout - not ethernet.
I am pretty sure I changed the clock source but in this P2P is the carrier providing timing or is one of my routers the DTE and one the DCE?
For carrier provided circuits like this, the routers should take clock source from the line.
