IR1101 boot issue
padraignotlad
I was trying to downgrade the iOS on an IR1101 router from ir1101-universalk9.17.02.01.SPA.bin
to ir1101-universalk9.16.11.01.SPA.bin.
I accidentally entered "boot system flash:/ir1101-universalk9.16.11.01.SPA.bin"
When I should have entered "boot system bootflash:/ir1101-universalk9.16.11.01.SPA.bin"
Now the router is in a boot loop because it can't find "flash:"
I've been able to ctrl+c to break and enter rommon> and manually boot, and then when I'm in the OS, I try to fix with the correct boot statement, but it doesn't take.
I've tried changing the boot statement by using the set command, but that doesn't save either.  Even when I type "sync" after.
How to I fix this?  I just want to forget about downgrading and load ir1101-universalk9.17.02.01.SPA.bin.
Padraig
17 Replies 17
Console into the router and reboot.  Post the entire bootup process.
Rignerd
Are you still having this issue?
My solution is to load the desired image to a USB drive, and plug it into the router.
If the router boots to rommon:
Boot the router from the IOS image on the flash drive
boot usbflash0:ir1101-universalk9.16.12.05.SPA.bin
then copy the image to the router:
copy usbflash0:ir1101-universalk9.16.12.05.SPA.bin flash:
then verify integrity:
verify /md5 flash:ir1101-universalk9.16.12.05.SPA.bin
verify the boot variable with:
show bootvariable
Remove the variabl;e you don't want with:
no BOOT system flash:ir1101-universalk9.17.06.05.SPA.bin
Add the one you want with:
boot system flash:ir1101-universalk9.16.12.05.SPA.bin
