Is my QoS Policy working?
Travis-Fleming
Hey community! We have a Cisco 4331 or 10 in our environment. Below is our current QoS policy. When I do a "show access-lists" I don't get a count for matches for access list 101, which is used in our QoS policy. Does that mean the access list isn't catching traffic for the "rdpfromlan" class map, therefor won't really do anything in our service policy tied to our MPLS interface Gi0/0/2? We are taking Citrix traffic and putting it on our MPLS network with a precedence of 2 via access list 101 so our ISP can properly QoS it if we ever reached bandwidth limits.
The 172.29.0.0/16 subnet is our remote network data subnets, and 172.17.99.0/24 is our citrix server environment subnet.
at-grsc-mpls-rt01#show access-lists
Standard IP access list 20
10 permit 172.16.1.166 (24833476 matches)
Standard IP access list CoreSwitch
10 permit 172.17.101.129 log
20 permit 172.17.101.2 log
Standard IP access list Management
10 permit 172.16.0.0, wildcard bits 0.15.255.255 (918 matches)
Extended IP access list 101
10 permit tcp 172.29.0.0 0.0.255.255 172.16.0.0 0.0.255.255 eq 3389
20 permit tcp 172.30.0.0 0.0.255.255 172.16.0.0 0.0.255.255 eq 3389
30 permit tcp 172.29.0.0 0.0.255.255 172.17.99.0 0.0.0.255 eq 3389
40 permit tcp 172.30.0.0 0.0.255.255 172.17.99.0 0.0.0.255 eq 3389
50 permit tcp 172.29.0.0 0.0.255.255 172.17.99.0 0.0.0.255 eq 1494
60 permit tcp 172.29.0.0 0.0.255.255 172.17.99.0 0.0.0.255 eq 2598
70 permit udp 172.29.0.0 0.0.255.255 172.17.99.0 0.0.0.255 eq 2598
Extended IP access list 102
10 permit tcp 172.17.99.0 0.0.0.255 172.29.0.0 0.0.255.255
20 permit udp 172.17.99.0 0.0.0.255 172.29.0.0 0.0.255.255
Extended IP access list guestwifi
10 permit udp any any eq bootps (24264 matches)
20 permit udp any any eq bootpc
30 deny ip 172.31.16.0 0.0.0.255 10.0.0.0 0.255.255.255
40 deny ip 172.31.16.0 0.0.0.255 172.16.0.0 0.15.255.255 (438495 matches)
50 deny ip 172.31.16.0 0.0.0.255 192.168.0.0 0.0.255.255 (11998 matches)
60 permit ip any any (62092796 matches)
70 permit icmp any any
class-map match-any voicefromlan
 match ip dscp ef
class-map match-any rdpfromlan
 match access-group 101
class-map match-any voicefromwan
 match ip precedence 5
class-map match-any cntrfromwan
 match ip precedence 4
class-map match-any cntrfromlan
 match ip dscp cs3
 match ip dscp af31
class-map match-any rdpfromwan
 match access-group 102
policy-map lanedge
 class voicefromwan
  bandwidth percent 25
  set dscp ef
 class cntrfromwan
  bandwidth percent 10
  set dscp cs3
 class rdpfromwan
  bandwidth percent 35
 class class-default
  fair-queue
policy-map wanedge
 class voicefromlan
  set precedence 5
 class cntrfromlan
  set precedence 4
 class rdpfromlan
  set precedence 2
 class class-default
  fair-queue
  shape average percent 10
interface GigabitEthernet0/0/0
 description To LAN
 bandwidth 100000
 ip flow monitor NetFlowMonitor1 input
 ip flow monitor NetFlowMonitor1 output
 ip address 172.17.101.1 255.255.255.252
 negotiation auto
 service-policy output lanedge
interface GigabitEthernet0/0/1
 description CID- CenturyLink ETH1000-XXXX
 ip address 1.2.3.4 255.255.255.252
 negotiation auto
 service-policy output wanedge
9 Replies 9
Muhammad Awais Khan
to confirm whether traffic is getting classified and policed , can you get the output from the Router of below:
show policy-map interface gi0/0
it will show you the packets classified and shaped/policed.
when your access lists don't show any matches, that could indicate that the access list somehow does not match the traffic flow. Try and temporarily change the access list to:
access list 101 permit tcp any any eq 3389
access list 101 permit tcp any any eq 1494
access list 101 permit tcp any any eq 2598
access list 101 permit udp any any eq 2598
or change the class map to match citrix:
match protocol citrix
and check if you get any hits then...
Ah so I’m right, there should be a count next to it correct when I do the show access list like the others had?
The count should be there indeed...
Hello
easiest way is as suggested @Muhammad Awais Khan look at the policy map
Kind Regards
Paul
Joseph W. Doherty
It looks to me as if your src/dest for your ACLs 101 and 102 may be "backwards", for their intended usage.
BTW, don't know if it's still true, but it may still be possible to use NBAR to examine CITRIX subtype, which allows you to treat differently screen scraping traffic from file copying and/or printing traffic.
EDIT: I cleared the counters on the interface, and if I do a "show policy-map interface gi0/0/2", on the MPLS interface, I can see the packet count going up for rdpfromlan, but if I do a "show access-lists" the count next to access list 101 does not go up? From the ACL the 172.29.0.0/16 subnet is the data subnet of our remote site, and 172.17.99.0/24 are our citrix servers at our data center.
at-chtx-mpls-rt01#show policy-map interface gi0/0/2
Class-map: rdpfromlan (match-any)
11886 packets, 823950 bytes
5 minute offered rate 19000 bps, drop rate 0000 bps
Match: access-group 101
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 11886/823950
bandwidth 35% (3584 kbps)
QoS Set
precedence 2
Marker statistics: Disabled
at-chtx-mpls-rt01#show access-lists
10 permit 172.16.0.0, wildcard bits 0.15.255.255 (92 matches)
80 permit tcp 172.16.0.0 0.0.255.255 172.29.0.0 0.0.255.255 eq 3389
90 permit tcp 172.16.0.0 0.0.255.255 172.30.0.0 0.0.255.255 eq 3389
100 permit tcp 172.17.99.0 0.0.0.255 172.29.0.0 0.0.255.255 eq 3389
110 permit tcp 172.17.99.0 0.0.0.255 172.30.0.0 0.0.255.255 eq 3389
120 permit tcp 172.17.99.0 0.0.0.255 172.29.0.0 0.0.255.255 eq 1494
130 permit tcp 172.17.99.0 0.0.0.255 172.29.0.0 0.0.255.255 eq 2598
140 permit udp 172.17.99.0 0.0.0.255 172.29.0.0 0.0.255.255 eq 2598
10 permit udp any any eq bootps (28677 matches)
30 deny ip 172.31.11.0 0.0.0.255 10.0.0.0 0.255.255.255 (266 matches)
40 deny ip 172.31.11.0 0.0.0.255 172.16.0.0 0.15.255.255 (14016 matches)
50 deny ip 172.31.11.0 0.0.0.255 192.168.0.0 0.0.255.255 (5620 matches)
60 permit ip any any (20769840 matches)
Hmm, your showing results from g0/0/2 but OP only had g0/0/0 and g0/0/1.(?)
Okay, if 172.17.99.0/24 is the LAN side and 172.29.0.0/16 the WAN side, the traffic going out g0/0/1 would have a
src of 172.17.99.0/24 and dest of 172.29.0.0/16
but the ACL being used for WAN egress is:
i.e. src/dest look "backwards".
Sorry the 172.29.0.0/16 is the LAN side of this remote site MPLS router, and 172.17.99.0/24 is over the MPLS WAN to our datacenter. This is from the perspective of the remote site router as it classifies traffic going onto the mpls coming from a 172.29.0.0/16 data subnet going to a 172.17.99.0/24 citrix server.
On our example router the Gi0/0/2 is the MPLS connection, Gi0/2/0 goes to our FTD 1010 firewall where our DMVPN traffic goes, and Gi0/0/1.X is our subinterfaces for vlan tagging.
Long story short example is we have a computer at IP 172.29.11.20 trying to reach a citrix server over the MPLS connection through Gi0/0/2 at 172.17.99.100 on port 2598 or 1494. We want to take that traffic and give it a precedence of 2 when it goes onto the MPLS network out interface Gi0/0/2 destined for 172.17.99.100 from 172.29.11.20.
