Is there any way design ASR+OTV Redundancy active/standby
TimeOut
 Is there any way design ASR + OTV Redundancy  by routing  instead EMM and bfd script ?
We have two router ASR and 2 ISP Link to redundancy.
So we now using EMM + bfd for control failover OTV link (active/standby) When Link ISP A down EMM action shutdown interface to down and script in router backup  will be enable interface to handle the traffic
Some cause EMM + BFD doesn't work such bfd monitor link down and up same time but EMM not running some command to complete
therefore link no switch failover to backup
I dont know if any way to using routing control OTV link redundancy active/standby ?
or you have any idea or suggestion to improve
ref
bfd configure interval 300milisec *3
balaji.bandi
what kind of links via internet or using MPLS or any other mode ?
how is your configuration looks like ?
we do have OTV deployment (but not using ASR, using nexus) - we follow below document and works for us.
https://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-7000-series-switches/guide_c07-728315.pdf
even i have tested CSR in Lab works as expected.
BB
Thank for reply
- We are using MPLS
now we do deployment OTV on ASR .  Core Switch allow vlan to ASR Router
I agree with you to change OTV on Nexus not ASR
post the running configs of your ASR/OTV edge routers, a First Hop Redundancy Protocol (FHRP) such as HSRP (Hot Standby Router Protocol) or VRRP (Virtual Router Redundancy Protocol) might work...
