08-30-2011 11:29 PM - edited 03-04-2019 01:27 PM
Hi All
can someone confirm if the below commands are used for throttling bandwidth please?
class-map match-all lan_traffic
match access-group 101
policy-map 512K
class lan_traffic
shape average 512000
interface Ethernet0
ip address 192.168.200.254 255.255.255.252
service-policy output 512K
Solved! Go to Solution.
08-30-2011 11:44 PM
Provided that acl 101 exists, and correctly matches the traffic you want to shape, it would indeed have the desired effect.
The effect is to 'shape' the traffic, i.e. making it fit within the preset bandwidth with minimal packet loss. Bursts are smoothed out over a longer period of time.
Perhaps it works simpler using the built-in default class:
policy-map SPOUT-Shape100Mb
class class-default
shape average 95000000
For this config, no acl is required.
regards,
Leo
08-30-2011 11:44 PM
class class-default
regards,
Leo
